puredrifting
Major Contributor
Buckling down into integrating the Sound Devices Mix-Pre 3 into my workflow with both the XT-3 and my C200. We've all heard that the C200 "doesn't have TC i/o like the C300 MKII does", right? Only half right. If you look at page 92 of the owners manual, you'll see that the C200 outputs TC over HDMI AND SDI! I knew about HDMI, but I didn't know it would output TC via SDI as well? So now the question is, SDI is a digital signal and besides taking in TC via HDMI Micro, the Mix Pre 3 utilizes Aux input to take in TC to sync to via it's 3.5mm input. So the questions are:
1. Does the Canon C200 actually transfer TC to the Mix Pre 3 via HDMI? (I suspect not as the SD website only mentions the C100 and says that it doesn't work?) If so, does the HDMI rec trigger also pass through, allowing the C200 to stop and start the Mix Pre 3?
2. Can the Mix Pre 3 Aux in via 3.5mm take TC in from the C200s SDI out? (I don't know, but I plan on trying it to see as I cannot find anything on the web from anyone who has tried this) Unfortunately I got rid of all of my miles of SDI cable when I bought the C100 MKI so I am going to have to order a cheap one to test this.
Anyone know if either of these will work with the C200 into the Mix Pre 3/6? I believe the Canon's SDI only outputs a digital signal and the Mix Pre 3 Aux input only takes an analog signal but neither manual gets this granular about the details.
I'll report back on this when the cable arrives.
