Chris,
if your back focus is off, you may never hit infinity at all, your wide angle lenses may never focus properly at open apertures and your zoom lenses won't track focus at all. Its a lot to give up.
Lenny Levy
Yeah, I get the infinity focus thing, but if I have a 20mm on the adapter or even a 28mm and I'm anywhere close to infinity focus on the lens, the depth of field should carry the focus.
Right?
I never thought my zooms tracked until I took my adapters to a collimator at a still lens shop. They were all off and after I collimated them properly the zooms tracked perfectly.
Nikon 80-200 f2.8 and Tokina 28-70 f2.8. I believe it was the same for my Tokina f2.8 80-200 but i can't recall.,
i thought my back focus was correct before I did the collimation. Quite enlightening. I don't think you can do it by yourself accurately except with a zoom that you know tracks correctly.
- Lenny
Tokina 28-70 f2.8.
- Lenny
hmmm... This back focus thing is new to me - will it affect sharpness or prevent me from anything?
Lenny,
Would you please explain what "the collimation" is... and how someone that have an adapter like an M2, can perform it?
By the way, I know how to calibrate the back focus on the RedRock.
Thank you.
Backfocus refers to the lens focusing it's image properly on the sensor which is in this case the ground glass in the adapter. Different lenses are designed to be spaced at different distances from the sensor. This distance is called the flange-focal length or FFL. If a lens has a flange focal length of 40mm then it needs to be 40mm from the gg in order for it to focus properly. If the lens is to far away you won't be able to focus to infinity (but you will get better close up focus). The opposite occurs if the lens is to close: You won't be able to focus as close up. In either case having the FFL be off makes the barrel marking on the lens useless because they are calibrated for when the lens is properly distanced from the sensor.
It's not just the infinity, but your near focus as well. Having the backfocus off is just never a good thing at all.
Davide's explanation of back-focus was good except that "Different lenses are designed to be spaced at different distances from the sensor" is not quite accurate. I think what he probably meant was that different lens mounts require different backfocus distances so that say, all Nikon F lenses should have the same back focus. All canon would have a different backfocus length.
