It's not worth the time getting an exact white balance in camera unless you have an external monitor that you calibrated perfectly for the specific room you are shooting in. If youa re using the cameras monitor/LCD it's not going to be perfectly calibrated and you are just guessing at that point. If you can somewhat close to the proper white balance it's pretty easy to fix in post if you know what your doing.
Same thing goes for exposure, you are going to be guessing using the camera LCD unless you calibrate it first. That's why zebras are used if you need very precise exposure. Personally I just make sure why highlights aren't clipping and I adjust my exposure in post. Adjusting exposure within .5 stop and white balance within 500K is not going to really cause any noticeable degradation issues to you footage.
For the Custom WB setting, Sony only requires the grey card to fill the centre mark in the EVF, but Canon requires that you fill the entire image with a grey card. Very inconvenient, that's why I used a white cap instead back in my T2i days. Not as accurate, but good enough in most cases.
