tackyattack
How much longer do you think it will be until we somehow get RAW video recording for DSLRs?
it's just a matter of time
I did some math a while ago, but it was not fine because I got my debayering stuff wrong; let's try to get it right this time:
a RAW still from my 550D is around 25MB, which is about 200Mbits/frame, I assume including lossless compression, which from my calculations turns out to work at 1:1.25 (18M*14bit/8bit=31MB/frame)
that is 3:2, if I can discard the top and bottom bits and live with 16:9, I'd get around 169Mbits/frame
if you want to record that at 24fps, you need 4000 Mbps; but that's with intra-frame lossless compression; how much can you save by going to inter-frame lossless compression? (using the fact that each frame is very similar to the previous one) I'm not sure, but I guess an additional 1:2 (1:2.5 in total) sounds conservative; with that you would still need 2000 Mbps; sounds huge, but it's well within the reach of modern SSDs, so that's already sounding feasible, all you need is a sensor that can sustain 24Hz full readouts, and a digic processor that can move all that data around at these huge speeds... (more on this later)
add in some non-aggressive lossy compression (a simple configurable quantitizer after a discrete cosine transform), and you can get 1:10 instead of 1:2.5, with extremely nice quality, which means 250 Mbps and you're still at 14 bit in full resolution and without color subsampling
that's with a 5.2K bayer sensor, which, when debayered, would give you a sharp 4K image
now, the problem: that's insane; have you seen any DSLR shooting 24 frames per second recently? I havent; that means it is not easy at all; but there's a way out: I don't need that much resolution
I want RAW 14-bit color information directly from the sensor, but I don't mind binning every 4 same-color photosites together; that way, I'd get a 2.6K bayer thing that would deliver a sharp 2K image; this solves a lot of issues with the sensor and the image processor, if the binning can be done in-sensor
that leads to 1000 Mbps with lossless 1:1.25 intraframe compression; with the previous 1:2.5 ratio, you'd get 500 Mbps with interframe lossless 14 bit love; with 1:10 for mildly lossy compression, you're at 125 Mbps
are those 1:2.5 and 1:10 compression ratios too optimistic? I don't think so, that 125 Mbps number is not too far away from what you'd get on a RED shooting at 3K
all in all, it doesn't seem too farfetched to me; I give it one generation more: 5Dmk4, the one whose first stages of design, for both the sensor and the digic processor, are being taken now, and which should come out around 2013-2014
edit: that's all for 24fps; increasing the fps means less-than-linearly increased data rate, as the efficiency of the compression would be higher
edit2: the big question is whether they'll want to put this in to a DSLR; maybe itt'll be reserved for 1D territory (and prices), or for video cameras; if that's the case, just wait 3-4 more years and it's cheap enough that you'll have it on DSLRs too, just because they can
That is slog, which will probably never come to DSLRS.
Try the Technicolor cinestyle and see if that works for you.
still, I feel the problem with RAW video on DSLRs is whether they'll want to implement it: which feature do you think Canon is working the hardest to get into their next generation of DSLRs, RAW video or an autofocus system that's good enough for soccer moms? I know RAW video will eventually come to DSLRs, it's just a matter of time; but before it gets here, we may be forced into a lower bitrate H.264 codec, just because everybody except us prefers it that way
What is this referance to, what do you call them ? oh yes, "Soccer Moms"?
Sorry, but the autofocus is an important facet of the modern DSLR, a place where the 5D series has been notoriously weak, and on the scale of importance to photographers a fast, accurate autofocus rates higher than raw video. So, given a certain development budget, and final cost of product, I know what will win out, sorry, but that's the way it is.
Dave
