Barry_Green
Moderator
Stephen, that sounds totally fine, and perfectly appropriate for the situation.
Completely crap-less.
Nobody asked nicely, but I figured I'd post something anyway.
This is a quick clip with an interview snippet and some on-water action footage. In the first "action" clips, I'm shooting from another boat, about 20 feet away. In the last clip, I'm on the same boat as the main "subject." And it's raining.
Nothing has been done to the audio. Period. No level adjustments in FCP. No filtering at all. Nothing has been done to the video, either. I figured this was an audio test, so why bother.
I will leave this up for the next couple of days, then take it down. It's raw client footage, and I'm hesitant to have it up any longer than it has to be.
--SM
Quick question. It's obvious from these posts that an external source is going to attain better audio than anything piped into the GH1. I haven't ever used an external audio source. Assuming it's a completely separate recording, is it complicated to synch up the video with the sound?
I just had a day doing interviews with the GH1/Juicedlink/Sony D50. I also ran the line out via a cable with attenuation to mic level into the GH1.
The sound quality from the GH1 was decent. A bit ruff and I could clearly hear AGC working it's ugly gain. But it could be used and would certainly be ok in many productions.
Listening to the D50's uncompressed 48khz/24bit audio files was crystal clear and very nice.
I had an AT897 above the interview subject pointing down connected to the juicedlink and then to the D50. A bit more work to start the camera and then the D50 but once I got used to it I felt comfortable working the procedure.
One thing that became very apparent was how easy it is to operate let's say a HVX200 if compared to a HDSLR. The price one pay for shallow DOF and light sensitivity.
Mission accomplished. :thumbsup:
Where is this mic mounted? If it's on a boom pole hanging eight inches away from the actor's mouth, then this option gets two stars. If it's on the camera, this option gets 1/4 of one star.(3) semi-pro microphone with good preamp into GH1 ($600);
In your audio chain (mic/preamp/recorder/gh1) which elements are contributing the most to the sound quality? How much would you loose by running mic/preamp/gh1 or just mic/recorder or even just recorder (with internal mics and preamps)?
An on-camera mike 15 feet away recording into an AGC system? I don't know what circumstances that could result in adequate audio... I gave it 1/4 because that's my opinion of how it would work.I'm surprised you only gave this 1/4 of a star.
Did the 5D have the Magic Lantern modification to eliminate AGC? If so, that'd move it up to a star in my opinion, but I don't care if you're recording 96KHz 24-bit audio on a $4,000 microphone -- if it's 15 feet away, it's gonna suffer.FWIW, Jon Fairhurst raved about the camera-mounted AT815b/Juicedlink CX231/Canon 5DMk2. He declared it the overall winner in his audio shootout and said "[in difficult conditions] a quiet preamp is the key to a good result".
I'm always amazed how much mic placement overrides everything else in the recording chain, as if it worth $100 per 4 inches.It's all about mic placement, even more than mic quality. Get a $179 Oktava MK012, put it on a boom pole eight inches away, and record it on a Zoom H4N, and you'll get audio that will be incredibly vastly amazingly superior to *anything* you'd get by running any mic mounted on the camera.
There is supposedly a device that is a pre-amp that also emits a silent tone that blocks the AGC somehow... I forget what it's called...
Anyway, I've heard it works but never seen any real samples despite requests for them.
The Zoom H4N Barry mentioned is the most commonly used device around these parts (GH1 forums that is).
