The ultimate XHA1 preset.
EXPLANATION
The Trend:
When we use high end digital cameras, sporting more than 10bit, high res, no compression 4:4:4 color space, we want to shoot with few contrast, in order to correct it during the post production process.
The Exception:
With highly compressed HDV cameras featuring only 8 bit the trick above can't be done without affecting the quality drastically, because the camera only uses few of the 8 bits available to describe the image, obtaining banding and resulting in a heavily deteriored footage if color corrected.
The Solution
Creating a preset that uses the most bits possible, with REAL BLACKS AT 0 IRE, and that can be used without any CC
Here is it:
http://www.vimeo.com/1768429
VISION02
This preset sports high contrast, 0 IRE blacks, less banding and better SN ratio.
VISION02 SETTING PARAMETERS
GAMMA CINE1
KNEE LOW
BLACK PRESS
PED 0
SETUP -9
SHARPNESS 1
HDF LOW
DHV 0
COR 0
NR1 OFF
NR2 HIGH
CMX CINE1
CGN 0
all other parameters at 0 (default)
EXPLANATION
The Trend:
The Exception:
The Solution
Here is it:
VISION02
GAMMA CINE1
KNEE LOW
BLACK PRESS
PED 0
SETUP -9
SHARPNESS 1
HDF LOW
DHV 0
COR 0
NR1 OFF
NR2 HIGH
CMX CINE1
CGN 0
