GH5 using Ex Tele Conv in video mode
coutard
hey
was wondering if the Extended tele mode was worth using, in documentary, when extra focal lenght might be needed
did a little test :
https://vimeo.com/276205349
password : GH5
conclusion is that it is acceptable. of course, you got less detail, but when needed I think it is usable.
what do you think of it ? do you use it ?
I use it almost all the time for wildlife work. If my output is to HD in the end, I'll also use 2X digital zoom in 4K UHD in addition to ETC.
Cheers, Pete
Ex Tele is a great option to have on the camera if one is ok with HD. You don't get the over sampling advantage of a larger sensor scaled down to HD but its still a very good looking mode to shoot with when you need the extra reach. Just be aware the results will be slightly softer vs shooting 4k and scaling to HD in post. Many don't consider that tiny bit of extra softness to be an issue at all so try it out and see if it works for you. Really if it looks good to you then it is good to use.
I use ETC all the time in 4k with no loss in quality - it's a great feature for extending the reach of any lens. As I tend to like to shoot with longer focal lengths and hate the wide angle look I generaly have it on all the time.
great to hear all of this
I'm a documentary shooter who shoots a lot in a day so 4K is out of the way for me as it would need to much SD cards and would be ridiculously expensive in hard drives
when using ETC in HD, does it still crops 'safely' in the 4K sensor or does it crops in the HD image ?
I did a quick test and when set in 4K, ETC does nothing for me, but I read its supposed to crop 1,4x !
On and off, no change for me
in HD it works well !
The GH5S is using the full sensor, pixel for pixel just like ETC already. The GH5 on the other hand has a 5184 pixel wide sensor that zooms in 1.4x when going to ETC / pixel for pixel mode at 3860 wide UHD. Losing this crop is the only reason I'm not interested in the GH5S.
Cheers, Pete
related: On the GH4, ETC does nothing in 4K modes, but is great in HD. Digital 2x in 4k mode looks 97% perfect, just eye balling it. (have not tested on test patterns yet)
It has some other benefits over the GH5 but i would not change,losing 4K ETC would be a big hit for me.
+1...This is one of the really big benefits of the GH5 over the S...it effectively every prime into 2 lenses without loss of quality...though a little discussed issue, it's one of the biggest features in the camera for me!
