Jim Martin
DVXuser Sponsor
Jim Martin
CinemaWorks
CinemaWorks
It was the CN-e 70-200 T4.4 firmware, that's all. If you are not using this lens, doesn't affect you.
Ah... On a serious tip, I was really hoping for proxy renaming to be fixed. Oh well...
You and me both. Also, the option to output UHD Prores HQ and 1080 Prores HQ from the Cinema RAW Development software would make life so much easier. DCI 4K 4:4:4:4 still requires another round of rendering and outputting to get to something usable for most mortals.
You can output 1080 ProRes HQ if you use one of the proxy options in CRD.
Thanks for the heads up, that's cool.
You're welcome. Sadly, choosing the lower quality and lower res output makes no difference in how long it takes to transcode the raw file to ProRes; it's exactly the same speed as transcoding to ProRes 4444.
Enable "quick development" and choose 1/4 instead of full (tabs under play tab in viewer). That helps a lot (same as within redcine).
I transcode all to Prores LT 1080 (1/4 debayer quality). Transcode to 4k 4444 only the clips that made it in the edit later, and relink those on fcpx project
