Hey guys
I'm shooting a music video and using the Canon T2i for the first time.
Couple of things I'm not sure about and thought maybe I can get some help here. I'm shooting mostly indoors. My lenses are 50 mm that came with the camera and 35mm/1.4 usm L series. I'm shooting 1080P.
So:
1) Lighting wise, I understand this camera behaves pretty well in low light, so I'll only be carrying with me a 500W Lowel softlight (with diffuser) just to cover the bases. Do you guys think that'll do the trick or should I go for a three-piece lighting arrangement?
2) White balance should be done custom, right? My experimentation yielded best results with custom. I'm doing anything else manually anyway. Also, if I shut the camera off between takes, should I set WB all over again?
3) Exposure level indicator: When I push the indicator button I see the small dot jumping along the exposure scale, but then it disappears after a few seconds and I can't see it anymore. Am I missing something?
4) As far as image quality goes, should I set it to Raw?
5) What shutter speed and aperture would you recommend for those lenses? How does 50 and 2.5 sound?
Again, this is basically an indoor shoot. Also, this is 90% static shots. I'm thinking of one dolly move and maybe couple of slow pans, but nothing too fancy. Mostly just lock it on a tripod and frame it accordingly.
I appreciate any feedback. Thanks!
So:
