time elapse? 2FPS
Elton said:
The big one was near the end of the clip. :)
It's ok w-h-o...mormons are used to it.
lol, im just messing. Felt like poking some fun. Nice footage though elton. What NLE do you use?
icicle22 said:
Barlow,
I am downloading now. Slightly off-topic but can you see why the wide angle adapter for the A1 doesn't fit on the H1 lens? I am curious as it is a 72mm thread mount so it should work but I was told it doesn't. Can you verify this on the 16x manual also?
In fact on BHphoto it is listed as being compatible with the a1, g1 and XL2. Can you see if it fits the H1 and it not, try to explain the reason? Of course, this is assuming you still have the H1.
Thanks man!
It doesn't fit on either the 16x or 20x. The A1 has a slightly different thread configuration apparently.
Ah man, just save up and get the 6x. Waaaay better.
w-h-o---I use FCP.
w-h-o---I use FCP.
I don't get it? How can the H1 and A1 both be 72mm and accept standard 72mm filters yet the WA adapter (72mm I should point out) is somehow booby trapped to prevent it from being used on the H1? You know this was done on purpose to perpetuate the need for the 6x wide angle.......right?
If I could save up for the 6x by the way, I'd probably just plunk down the extra for an A1 as a 2nd camera. Can't see investing that much into a lens and still only having the ability to shoot one camera at a time you know?
