thin or thick in 30p?
Gweilo66
Any thoughts on which is the safest setting? I'm working on clips for the web but I don't know if the client will use the ftg for other things later. They have only specified 30p.
Depends on how the footage will be used. THIN = higher resolution, great for web, but perhaps will flicker on an NTSC CRT television. THICK = lower res, won't flicker, but -- it's lower res.
Is it for 16:9 or 4:3? If using "squeeze" mode, always always always use THIN.
I normally advise to always use THIN unless you know for certain that the footage is going to be played on a CRT TV. Plus, you can always turn THIN into THICK in post, but you cannot turn THICK into THIN.
