Theater asking for this format, how do I do this??
Denialorcoped
I am showing a short film at an art theater. They are asking for a DCP Dolby Format (*for D-cinema).
I don't really know what this means. I am editing cineform files in adobe premiere. Will I be able to deliver what they are asking for?
None of the video editors master out to DCP (Digital Cinema Package). I recently completed a short and one of the deliverables we requested from the post house was to create a 2K DCP for us. Its a hard drive with the movie on it in a specific format. Its a universal standard and you can walk into any digital theater in the world, hand them your drive, and it plays perfectly.
I'm not aware of any free DCP workflows out there. There are some opensource attempts but last I saw they still required some utilities that cost money. If you need a DCP I'd contact the local post houses in your area and start to get quotes.
Thanks, it makes a lot more sense now.
They said if I can't deliver a DCP then they can still show a Bluray; Do you think I should just burn it to a bluray instead? Sounds much easier, but not sure how much worse the quality will be...
The easiest route is to author a Blueray, but it won't look anywhere near as good as a DCP of the same material due to compression. If you have no budget for this I'd say just go with the Bluray.
Grrrr, I HATE the thought of projecting my movie knowing it's not the best quality; you put so much time and effort in, you kinda feel you deserve to have it the best quality it can be ya know?
I did some further research and came across some DCP plugins, like Quivis Wraptor: http://www.quvis.com/?Action=Products&SubAction=wraptor
It sells for $700 which aint bad. Only thing is it is for Final Cut and I am using Premiere. I suppose I can just bring the whole uncompressed avi into final cut and use the plugin from there...
You could also use streamclip to convert the AVI to ProRes & save a rendering step in FCP. Streamclip is pretty fast on a reasonably fast machine. (and it's free and a really useful swiss army knife sorta thing...)
I believe OpenDCP is a successor to Open Cinema Tools, and uses the AS-DCP library.
Definitely start with OpenDCP if you're going the open source route. It's all command line though at the moment, although a GUI is planned for a future release. Personally I like the command line, but I'm probably in the minority here.
I've tested it on my local computer and it seems to work well. I haven't tried playing it back as I don't currently have access to a DCI projector setup, but there are reports online of it working for people.
Stupid thing is, the OP is already using Cineform - which is a wavelet/JPEG2000 based codec and exactly this is used in Digital Cinema. The DCP (Digital Cinema Package) is actually just a wrapper or container for the wavelet codec and some additional information and scripts.
So in a ideal world, any digital theater should be able to play Cineform files without any further recoding and quality degradation - but sadly they aren't, the hardware is there but the software does prohibit it.
Frank
Frank
Good point. However, the DCP JPEG2000 data is in the XYZ color space with a gamma of 2.6 (not sure about what Cineform uses). This is speculation, but I doubt converting full quality JPEG2000 data from Cineform to the DCP JPEG2000 format would incur a visually noticeable loss in quality though.
Hi, Denialorcoped.
Glad you found out that Wraptor was a DCP option. If you’re using any editing program with a Mac OS (Adobe, Avid, etc), you can get the Apple Compressor plugin and make a digital cinema package with Wraptor.
We just released Wraptor 2.0 http://www.quvis.com/ and it gives you much better quality and security than you could get on BluRay or DVD – http://www.quvis.com/products/wraptor-2-0/enhance-security-optional-encryption/
You mentioned DCP Dolby Format. I can see why that's confusing. There's really no such thing as DCP Dolby. DCP is a standardized file format that meets DCI specs, wiki has a good overview: http://en.wikipedia.org/wiki/Digital_Cinema_Initiatives
Does this answer your question?
If you have any questions please send me an email. I can be reached at mweaver@quvis.com.
Hope your showing went well, and hope we can be of some help to you.
Thanks,
Mary Weaver
Administrator, QuVIS
While cineform uses wavelets, it isn't the JPEG2000 version of wavelets. The cineform method has a way of doing
intra-frames with wavelets and that's not JPEG2000. Similarly just because DVD and H264 use the discrete cosine transform,
this does not mean that the file you pulled off youtube will play on your DVD player.
