Alex DePew
Señor Schmarty Pants
Jack Daniel Stanley said:The set up refers to the absolute black level. The rest of the world uses a setup of Zero (superblack) and North America NTSC uses 7.5 (black) The setup of 7.5 sometimes called "The Pedistal" and then can be manipulated via teh Master Ped or Master pedestal.
And what Jarred said is right -- the setup really ony applied to ananlog equipment and gets some extra play in at the dark end of the scale because its a cheat -- it boosts what's percieved as black. But shooting digital you should always use the full range which is a setup of 0.
So you can forget about the setup and what it means -- just set it to 0 then play with your Master Ped.
Thanks Jack. I'm pretty sure the default on the 100B is set to 0, so I should be fine.
