William_Robinette
Shallow Member
Ok, so I was reading the HVX200a thread and thought that we haven't had one of these for the DVX in a while so why not? The DVX is old, and although a workhorse, isn't too smart a buy right now with the current crop of HD camcorders, and it isn't getting any better. I don't know if Panasonic has anything up their sleeve or not, but lets see if we can't compile a list of wants for a new version of the DVX.
I think there are a few things we should all remember however.
1) The HVX sits at $5,200 w/o cards from a reputable dealer. Panasonic is going to protect this.
2) The DVX sat at around $3,500 with rebate for a long time. the A1 is around there now I believe. This is the mark we are going for, and where the (large) gap in their lineup seems to be right now.
So with that in mind, some ideas I don't think are too outlandish would be as follows:
I don't know if it's possible with the same sort of Leica lens system they run on the DVX/HVX, but a torqued iris ring would be killer. I want the same general build as the DVX.
From the HVX protection standpoint, I think it's pretty good. HVX gets you P2, DVCPRO-HD, VFR 2-60p, 1080p among other things.
We don't have 1080p on this, but I would take a native 1280x720p chipset for the increased pixel size. No CMOS because rolling shutter doesn't seem to be taken care of yet by any camera manufacturer. The SD AVC-HD system is already in one camera Panasonic's broadcast division makes, so that is an easy transplant, and the cards are inexpensive and easy to get. Panasonic even makes a P2 Store-esq unit for SD cards. AVC-HD also supports uncompressed PCM audio which is awesome, and according to Barry Green, at 8mbps matches HDV already, so 18 mbps should look pretty good.
I think this would be a far forward thinking camera. There isn't really any backwards compatibility here, regarding standard DV and down conversion to it. Maybe you implement this through available down conversion via firewire? Who knows. I hope Panasonic would have the guts to take a camera this far. I am fine with the image tweaks the DVX offers, but more would always be better.
What do you think? Feasible for +/- $3,200? Protects the HVX but good alternative to the A1, V1U, HD110? I'd pick one up in a heartbeat.
- 3x 1280x720 progressive CCD imagers
- Same wide 4.5mm Leica Lens, but give us 58-63mm on the long end (13x-14x zoom)
- Nice 3.5" LCD at 480x360 at least (640x480 better) putting info in the letter boxed areas ala HVX
- HDMI 4:2:2 Uncompressed Output
- AVC-HD at 18mbps to SD memory cards (two card slots)
- Same versatile 2 channel audio system
- 24p, 30p, 60p (NTSC) 25p, 50p (Pal)
- Image display flip
