The NEX-FS 700 4K Camera Announcement & Latest Info!
Does anyone know if there is a place on the FS700 to mount the Sony HXR-FMU128 Flash Memory Unit like there is on the FS100? Thanks in advance![h=2][/h]
Not sure if this has been discussed or if we've actually heard anything from Sony, but when the 4k release comes out does that mean that 240fps will be at 4k, 480 at 2k maybe and 960 at 720p??
That is a good question . I consider to buy HXR-FMU128 for fs100 but I will get it only if I know it goes with fs700 as well . In one or two years I wish to get fs700.
Look above your post, just answered it. =P
Sorry Kholi I just did not see it . I need some sleep :smile: Thanks
I'm writing this out of curiosity and I couldn't ask for better insight than what is given to me on this forum, it's a blessing.
Do you think the general image quality of the black magic camera will be better than the fs700?
Do you think the update to 4k will be expensive?
Do you think the higher price of the fs700 is worth it compared to the black magic camera?
I just want some thoughts on the situation I find my mind in after NAB!
How can anyone else answer those questions?
They are questions only you can answer based on your own requirements and budget.
Valid point. I guess I'm just after some comparison between the two. Maybe from people who are in a similar situation. I was dead set on the fs700, but after NAB I'm considering the options. My conflict isn't important, I'm not trying to express my problem, just was interested in seeing what others had to say about the current situation in the under 10k range.
I don't think you're making a smart comparison, the FS700s biggest selling point is the Slow Motion (at this stage) the Black Magic doesn't even have slow motion.
I know personally that I want to purchase both, because they serve 2 different needs.
Also, I've heard from a few people the rolling shutter isn't amazing on the Black Magic. Not that it is as bad as a DSLR, but, from what I was told, not as good as the FS100, which I've been fine with. Now, the BM is still in beta, and this is second had knowledge, which all it means is, it's something that probably should be checked. Also, FS700 has ND filters. Can work with SDHC if you want. Better in low light it appears. This is why you can only answer these questions.
While 2 products are not comparable, it is safe to say that FS700 is a 'more versatile' tool and it covers a broader range for everyday professional use.
If you are thinking BM camera as an alternative, probably you'd be fine with it too.
Well neither camera is available yet, so almost any comparison would be conjecture, but here are my thoughts as to how things stand at the moment (as someone who's also in the process of deciding on a camera purchase):
FS700 benefits:
- Larger S35mm sensor
- Slow-motion frame rates
- Better low-light capabilities
- 4K upgradable
- Built-in NDs
BMCC Benefits:
- 13-stops DR
- Broadcast-ready internal ProRes/DNxHD recording
- Internal RAW recording
- Superb file-naming/metadata abilities
- Davinci Resolve for colour grading
Now, for some perspective, I just purchased (on the day the BMCC was announced) a PIX240 external recorder, with the intention of pairing it with either a used-F3 or an FS700 when I eventually bought my camera (I've always rented in the past). My reason for wanting it was to gain the speed and ease of the ProRes shoot-edit workflow with synced-sound (which saves MASSIVE amounts of time in post, and provides superb broadcast-ready image quality).
I was torn between getting a used-F3 and an FS700 because the high-DR of SLOG on the F3 provides an image with significantly more 'depth' to my eyes, it looks creamier and more organic, more filmic - and that's the sort of image I've been trying to make lower-cost cameras create for the past 4 years now. The FS700 however, offers amazing slow-motion capabilities, and 4K down the line, and my concern with opting for a used-F3 lay mostly in whether the 4K or slowmotion abilities of the FS700 would hold more appeal to producers (it's an image-quality vs. feature-set debate really).
In the end, I decided that the greater DR and the image quality of 10-bit SLOG (to a ProRes recorder) was the better choice for me (a position that's aided by the fact that FS700 rental should be very affordable (for times when I need the slow-motion capability).
When I saw the announcement of the new Blackmagic Cinema Camera, that really cemented things for me - I realised that the 13 stops of DR (which should be very close to SLOGged F3 footage) and internal 10-bit ProRes recording, are the features that really matter to me, and at the BMCC's incredible price-point - they overrode my concerns about the smaller sensor-size.
As such, I've already put down a deposit on a BMCC.
So if image quality and workflow speed are your priorities, I think the BMCC is a no-brainer for the price-point. However, if an FS700's AVCHD codec is sufficient for your needs (or if you can budget for an external recorder as well) and you're after something with a broader feature-set (and probably superior controls/ergonomics) then the FS700 is definitely the go (and still very competitively priced for what it offers).
In the end, as always, it's a question of needs. Do you need higher ISO than 1600? Go the Sony. Do you need higher frame rates than 30fps? Go the Sony. Do you need the convenience of built-in NDs? Go the Sony. Do you need a camera that 'looks' like a camera? Go the Sony. Do you need really high image quality? Go the Blackmagic. Do you need an extra $5-6k in your pocket? Go the Blackmagic.
For me the single-most exciting aspect of opting for the BMCC, has nothing to do with the camera at all - it's that it made it possible for me to take a very good deal and invest in a new 6-lens set of Zeiss CP.2s (an option I hadn't even considered previously - I just got very lucky with the way things worked out timing-wise).
Hope that helps.
I was kind of buying the f700. Then i preordered a BMCC as for now despite the specs, i was more impressed bu the image quality of the second one. Im still waiting for Sony to provide full HD footage which could impressed me enough to push the "buy" button... Maybe i will happen , maybe not
FS700 benefits:
- 4K upgradable
- Built-in NDs
BMCC Benefits:
- 13-stops DR
Hope that helps.
Based on your vimeo clip, I can see why you'd be keen. Seems like the perfect cam for action sports. Of course the fs700's feature set will become more common, and cheaper...as with everything.
The main reason for create "film-look-like" effect is NARROW DOF with we have in film cameras.. produced by very FAST cimena lenses ... and what Canon 5D camera was able to produce with even F2.8 lenses - as it's sensor size about 2.5 times bigger !!!.. without this Canon initiative we probably DO NOT HAVE our FS-100, not C-300, not F3, FS-700, C-500 TODAY!! :) .. and do not forget, that if we want the same DOF as 5D produce on our Super-35 sensor cameras we need at list F 1.8, F1.4 or F1.2 lenses!! .. So ? What we can get on really small sensors? .. the same as we have on regular camcorders before ?? ..don't know about you.. but I don't want even look to that side! :)
Someone think I'm wrong in it ??
I didn't quite understand that, but did you just say the film look is created by shallow depth of field?
