FS7: The FS7 will not allow this audio setting.
Status
Not open for further replies.
Amadou
Carbonite Member
On the EX1 we had the ability to use the side dial to set levels for chanel 1 and use chanel 2 as a backup which would record at 20 percent lower volume. But on the FS7 the two chanels work independently from each other. So you have no way to have chanel 2 follow chanel 1. That seems to be a major step back.
normally you can have two input 1 and control them manually i alway do that to have differents levels on same audio input.
I've seen what you're talking about and it's mostly on "prosumer" cameras. I have a client that has a lot of "handycam" Panasonics that let you just plug an XLR into one input and then assign it to both ch's. Just send ch. 2 the same signal(feed) and pot it down. Or if it's a mic running straight into the cam(not through a mixer), just put a splitter on the XLR to send it into both ch's.
Must be an amateur if he's recording audio in-camera. That's what Sound Recordists are for. :laugh:
This leads me to the level + sides issue. Isofar as you can set recording volume on the side, why use internal level? I don't get it.
plug xlr mic on input1 and in menu choose input1 for ch1 and input 1 for chanel 2 next, on left camera turn manual on two slot and setup your level. you can't do that with internal mic, only xlr mic is supported if i well remember. i just did the test with my xlr mic and i can control level with the manual wheels no problem.
Status
