The scopes are from DaVinci Resolve, they are independent of video or data levels (levels are set at encoding). 0 represents black and 1023 represents white (the numbering refers to 10 bit values, i.e. 0..255 * 4).Cary, if only there was any budget.I visually raised the blacks a little above standard 16 based on numerous films I've seen. Seemed comparable. Could you maybe explain how the PARADE scale of 0 - 1023 relates to 0 - 255? I don't get that part.
It's 2018; grade however you want until someone is paying you a lot of money to not...and then do it a certain way.
Could it all be better? No doubt about it. But no one but forum nerds are going to think anything is wrong.
That's great, just trying to give my 2 cents on it.No, each clip in the teaser was independently adjusted. I could make a blank render if you feel like playing with it?
I'm done with it, learned a ton, releasing tomorrow, and I'm moving to the next thing.
Just so happy the GH4 was up to the task of filming it.
No, it is a quick regrade, I did a global correction then cut the scenes and made small individual adjustments.correcting gamut, you mean by lowering blacks down to black. this is minus full grading right?
Thanks for messing about with it!
