CAMCORDERS: Testing the NX800 this Week...
I wanted to share some thoughts as I test out an NX800 this week for a possible change from my Panasonic PX-270s and CX-350. This is not a forced upgrade so it will probably be more on the picky side as the new Sony has to be an improvement for me to consider it. I will go with the Z200 if I upgrade but the NX800 was less expensive to rent...
Overall Impressions - It is a really nice camera. I am impressed with the lens and the imaging sensor. Both are performing very well. The lens has very little geometric distortion even at full wide. Straight lines are straight on doorways etc... Color rendition is quite accurate out of the box and the menu offers plenty of hue/saturation flexibility to dial in very accurate color. Like the Sony still cameras I use, the image starts on the flat side and requires some saturation boost to get it where I prefer.
The build is nice and the design of the camera is comfortable to hold. Handheld seemed very natural and the camera is about the perfect weight. The zoom rocker can get a really slow creep/start and is fine overall. I wish it had a little more travel as small moves result in a lot of change in the zoom speed. Same goes for the rear zoom controller feel. Overall it is a solid implementation but I think it can benefit from some refinement. The step from going very slow to a little faster always results in a visible jump. I would like to see Sony improve this. I am others got on Panasonic when they released the CX-350 about their LANC implementation and they did really improve the handling to where I would put it above this Sony camera a bit.
Variable ND is really nice. I enjoy the ability to choose an F-stop when you are outside and let the ND take over. Great if you wanted to film an event like a sports game in a deeper DOF.
The Noise Suppression is top notch. I can see little to no difference between "OFF" and "Full". I kept it at "Mid" but high would be no problem which is a great tool to have.
The audio preamps seem to be very nice. I plugged my usual cardioid condenser mic which is best at -40dB and it sounded very full on the low end with crisp highs. Solid. The adjustable limiter is awesome. I wish more gear had this feature!
I like this camera but I do see some things that I do not care for. Maybe they can be addressed, maybe not. But here goes the negatives...
The screens are undersaturated, not exactly color accurate and there is no setting adjustment other than 3 steps of brightness. As an old school type shooter, I think the viewfinder is the focal point of the camera. I prefer to dial them in so I always have a trusted source to view my color and exposure. This viewfinder experience is a disappointment. The middle setting is pretty close and I can set exposure using it but it looks pretty bad imho. It is sharp enough but it almost looks like LOG footage. And maybe I have missed some setting or something? (I am not shooting in S-log3 or anything).
Image controls are lacking in the menu. While the color has a lot of options, there are not many ways to change the tonal character of the image. You get three "Base Looks" (S-Cinetone, ITU709 and 709Tone). S-Cinetone has pretty accurate color but also has a touch of a bleach bypass look going on. Not huge but there is no way to 'dial out' that bump in the high mids/highlights. You only get some black level adjustment and knee. But the knee is disabled with S-Cinetone. So chuck that one out for me... ITU709 is nice looking and has pretty accurate color (a little less accurate than S-Cinetone) but has the knee available. 709Tone is a more flat version of ITU709. When I worked with it the overall look was still muted even after I raised the saturation quite a bit in the Matrix. ITU709 is the base I would use if I owned the camera. Luckily, Sony has done a nice job with the overall look of the camera. Blacks were a little low for my tastes but not a large adjustment upward. It creates a nice image but you get what you get.
There is no way to give Scene Files a unique Name. The scene files are named after the base look. But I can not fine a way to save a scene file and give it a unique name. So if one created three scene files using the same base look, they appear as the same name in the list! Am I missing something? Every camera I have ever owned has some form of naming convention of scenes you create. I hope I am off base here.
There is not permanent button for Steadyshot. Yes, you can assign a button but this is a major feature you want to turn on and off and they make NightShot a button instead?
The focus wheel is rather stiff from my perspective. I prefer a smooth focus wheel so you can adjust it with a finger rather easily. The Panny's have super smooth focus rings. Kind of a bummer.
There is no way to decouple auto white balance from the "full auto" switch. On my Panasonics I like to have the full auto switch represent auto iris, auto gain and auto focus. There are many times in the sports world that these settings work just fine. But auto WB is always left out and the menu lets you determine this. I have not found a way to do this on the Sony. the switch is very easy and convenient as opposed to going in the menu and turning stuff on and off. So the full auto switch is kind of useless to me if it always has auto WB involved.
I had hoped for some features with the app that would help me when I have the camera up on a high stand. Mainly being able to change the white balance setting from preset to A or B. It only lets you alter the existing WB setting. This is a big deal when you start filming in sunlight and the game goes under sodium vapor lights. Also the ability to turn output characters on or off. So much potential but I am not sure if Sony is open to develop this or not.
Auto focus is solid but I came across a few situations where it sticks on a subject and it will not let go. I have two flower pots in my front yard and zoomed way in, the first pot gets locked on. Many times when I slid over to the 2nd pot it just stayed with the 1st pot. If I moved extremely to the edge it finally grabs the 2nd pot. Not the best imho. I executed the same shot with my CX-350 and it was perfect. Now, this was with "human priority" set to on in the menu. If I turn this to "off" the two pot scenario executed flawlessly. So the smart AI stuff is not smart enough yet...
Then there is the attached image. All of this white and edge stuff to grab on this house and it is STUCK on this skinny branch. I could not get it to let go of this branch.
These are specific situations and overall, the AF is acting well. But for general videography, there is room for improvement.
Will I upgrade? It is a tough decision. The Sony image does look more refined than my current cameras along with great features. As Doug mentioned, it is an evolution of the camcorder. I wanted it to be a slam dunk but life is always more complicated than that...
Thanks for sharing your experiences. My take all these 1” cameras use the same or similar sensor so it comes down to whether a given manufacturer features fit the type of work you do and whether you like their color implementation. I use camcorders for event work and don’t see a need or benefit of Log type profiles. I don’t think they make any claims of DR benefits. I believe the idea is if you add this to a FX6 multi camera shoot you can use the same log grading process.
I wouldn’t mind changing to Sony because I don’t like Panasonic poorly thought out controls but I can’t justify the cost of doing so.
I would agree. The image from the CX350 and the Z200 was very similar in terms of dynamic range. Maybe a little better on the Sony.
I am a little frustrated as want to be able to tweak the base ITU709 profile but the tools are not there in-camera. My impression of the Z200 image outdoors was similar to the CX350 where the highlights are the first thing I noticed. I adjusted the knee but that only gets you so far. If I bring it into my NLE it is an easy curve adjustment and the image looks great. But I doing more live streaming stuff and need to have that look coming out of the camera. So I was hoping 5 years of sensor development would have yielded a bit more. Or that plenty of image tools would be included in the menu.
I have been trying to reach somebody at Sony that knows higher level things but not much so far. The manual says you can import a "base look" in the form of a LUT. Ok, that would be great but I associate LUTs with LOG shooting. I do not want to shoot this camera in S-LOG3. If one of the imported LUTs can be used with normal non-LOG shooting modes I could get to a happy place and create an image better than the CX350. We will see if anybody at Sony knows this. I will report back if I find out anything.
Ideally, one could get the ITU709 starting point, tweak it, export that new base look as a LUT and bring it into the camera for non-LOG use. Sounds complex but not so much for us camera nerds.
This is from the manual but I not quite clear if it means I can do what I am looking for:
"The base look/LUT selection options for imported 3D LUT files are common to [SDR(BT.709)]/[HDR(HLG)]/log shooting mode, but color gamut and gamma conversion are not performed according to these modes."
I own the Sony FX30 and A74. I've played around with Log. What I've found the both Log and a Lut effects the exposure tools readings making that much harder to judge exposure. For example 100 ire in Log might be 96 and depending on the Lut you use can change that. Even if the Lut makes it look like 709 you can't easy understand what the proper exposure should be. If for any reason you need to switch between 709 and Slog with a Lut it makes that much more complicated. So I'd stay away from it unless you want to commit to shooting that way all the time.
This is the heart of my question and it is complicated. Maybe I did not word it well but please re-read my posts. Since it is camera-specific, it is difficult to discuss without all knowing and using the camera. I want to alter/affect the camera profiles and wondered if the LUT import system would allow this for non-LOG shooting.
Based on every camera I’ve owned I wouldn’t think that’s possible. While profiles can be customized in camera they fundamentally differ from LUTs in that they bake a look into the video where as a LUT only effects the camera display that subsequently can be applied to LOG in editing to match the look seen on the display.
Now saying how LUTs have been traditionally used I thought recently cameras marketed at social media might allow custom LUTs to be imported and baked in to achieve fun looks without needing to be edited much like phones do. I have doubts that this camera would do that based on who it’s marketed to.
". . . might allow custom LUTs to be imported and baked in to achieve fun looks without needing to be edited much like phones do. "
I'm back. I was naughty and got banned for two weeks. Almost decided not to come back, but we'll see. Not sure I want to walk on egg shells from here on out.
Yes, you can do that with the Z200. Import a custom LUT . . . apply it . . . and record it.
I wondered where you were Doug. I spoke with tier 3 Sony support and the rep was nice but did not know if the LUTs system could be applied to a rec 709 look or a "base look".
Doug, do you know if the camera can do what I am after? Basically adjusting the gamma curve for the ITU709 base look? My thought was to add a simple LUT which only has some curve adjustments that would 'augment' the base look. But the LUT would need to be added to the ITU709 scene file instead of LOG mode.
Nope, you can't do that. You can only apply an imported LUT to S-LOG3.
The funny thing about Doug if you've seen his videos, he's the most calm and collected guy, but on an internet forum, he turns into the hulk. I still like both Dougs as long as I'm not on the receiving end of his gargantuan ire. I always wanted to use gargantuan in a sentence.
I'll take it. :)
what did you get banned for, lol
I was told that I said something too political, but the actual post that crossed the line was not identified. I don't recall saying anything that was too political, and the only post I could find that maybe crossed that line still exists. Why didn't a moderator delete it if it was so offensive? So, the fact that that post is still on the forum makes me doubt that was what got me banned. Seems very strange not to tell me WHAT it was I said so that I can learn my lesson. Imagine if you just came up to your kids and smacked them in the head without saying exactly what they did that made them deserve a smack in the head.
Thanks. Wishful thinking on my part.
Maybe I'm not fully understanding what you're after Bassman ... but with several different free software programs (Resolve, Catalyst Browse, etc) you should be able to create your own custom LUT and then export it... to then bake in that look in camera. So technically, you wouldn't be "shooting log"... you would be creating your own "look". Also would assume you could edit "scene profiles" like you can do with Sony's mirrorless cam's (I have the a7sIII and still occasionally use a PP created by Chris Young from this forum).
And if you want to start with an existing LUT made by Sony or someone else and change it a bit... there are other programs to do that... like LUTCalc. (who's creator used to be on this forum along with lots of other very talented, thoughtful and sharing folks who no longer visit). Unless there are limits to the number of LUTS you can have with Z200 / NX800... you could create offsets for both color balance and exposure in "sets" and with naming... be able to adjust your "look" by switching LUTS.... which would give you nearly limitless options.
(though just to be clear - I would always prefer to shoot log with nearly any Sony camera and then apply LUT / grading in post, but do understand their are certain situations - like handing over footage or "straight to air" where a "baked-in look" is needed.)
Mark, everything in your post is correct and is applicable to the Z200/NX800.
Thanks for your post Mark and Doug. What I am after is the adjustability but not being forced to shoot the camera in LOG mode (ISO 1600 base). I found the ITU709 look to be pretty close but wanted more highlight reduction and a little less crush in the blacks. But the scene file adjustment tools were just not there to accomplish this.
My thinking is that the noise levels and dynamic range will be compromised by shooting at base ISO 1600 and might take away some of the gains of adjustment.
Also, what about color? I can dial in the color using the base look and multi-matrix in-camera but if I use a LUT I will lose all of that and have to rely upon the LUT's color right? So I would need to dial in the color at the LUT stage which is more complicated.
Please tell me if I am missing something?
