Bassman2003
I wanted to share some thoughts as I test out an NX800 this week for a possible change from my Panasonic PX-270s and CX-350. This is not a forced upgrade so it will probably be more on the picky side as the new Sony has to be an improvement for me to consider it. I will go with the Z200 if I upgrade but the NX800 was less expensive to rent...
Overall Impressions - It is a really nice camera. I am impressed with the lens and the imaging sensor. Both are performing very well. The lens has very little geometric distortion even at full wide. Straight lines are straight on doorways etc... Color rendition is quite accurate out of the box and the menu offers plenty of hue/saturation flexibility to dial in very accurate color. Like the Sony still cameras I use, the image starts on the flat side and requires some saturation boost to get it where I prefer.
The build is nice and the design of the camera is comfortable to hold. Handheld seemed very natural and the camera is about the perfect weight. The zoom rocker can get a really slow creep/start and is fine overall. I wish it had a little more travel as small moves result in a lot of change in the zoom speed. Same goes for the rear zoom controller feel. Overall it is a solid implementation but I think it can benefit from some refinement. The step from going very slow to a little faster always results in a visible jump. I would like to see Sony improve this. I am others got on Panasonic when they released the CX-350 about their LANC implementation and they did really improve the handling to where I would put it above this Sony camera a bit.
Variable ND is really nice. I enjoy the ability to choose an F-stop when you are outside and let the ND take over. Great if you wanted to film an event like a sports game in a deeper DOF.
The Noise Suppression is top notch. I can see little to no difference between "OFF" and "Full". I kept it at "Mid" but high would be no problem which is a great tool to have.
The audio preamps seem to be very nice. I plugged my usual cardioid condenser mic which is best at -40dB and it sounded very full on the low end with crisp highs. Solid. The adjustable limiter is awesome. I wish more gear had this feature!
I like this camera but I do see some things that I do not care for. Maybe they can be addressed, maybe not. But here goes the negatives...
The screens are undersaturated, not exactly color accurate and there is no setting adjustment other than 3 steps of brightness. As an old school type shooter, I think the viewfinder is the focal point of the camera. I prefer to dial them in so I always have a trusted source to view my color and exposure. This viewfinder experience is a disappointment. The middle setting is pretty close and I can set exposure using it but it looks pretty bad imho. It is sharp enough but it almost looks like LOG footage. And maybe I have missed some setting or something? (I am not shooting in S-log3 or anything).
Image controls are lacking in the menu. While the color has a lot of options, there are not many ways to change the tonal character of the image. You get three "Base Looks" (S-Cinetone, ITU709 and 709Tone). S-Cinetone has pretty accurate color but also has a touch of a bleach bypass look going on. Not huge but there is no way to 'dial out' that bump in the high mids/highlights. You only get some black level adjustment and knee. But the knee is disabled with S-Cinetone. So chuck that one out for me... ITU709 is nice looking and has pretty accurate color (a little less accurate than S-Cinetone) but has the knee available. 709Tone is a more flat version of ITU709. When I worked with it the overall look was still muted even after I raised the saturation quite a bit in the Matrix. ITU709 is the base I would use if I owned the camera. Luckily, Sony has done a nice job with the overall look of the camera. Blacks were a little low for my tastes but not a large adjustment upward. It creates a nice image but you get what you get.
There is no way to give Scene Files a unique Name. The scene files are named after the base look. But I can not fine a way to save a scene file and give it a unique name. So if one created three scene files using the same base look, they appear as the same name in the list! Am I missing something? Every camera I have ever owned has some form of naming convention of scenes you create. I hope I am off base here.
There is not permanent button for Steadyshot. Yes, you can assign a button but this is a major feature you want to turn on and off and they make NightShot a button instead?
The focus wheel is rather stiff from my perspective. I prefer a smooth focus wheel so you can adjust it with a finger rather easily. The Panny's have super smooth focus rings. Kind of a bummer.
There is no way to decouple auto white balance from the "full auto" switch. On my Panasonics I like to have the full auto switch represent auto iris, auto gain and auto focus. There are many times in the sports world that these settings work just fine. But auto WB is always left out and the menu lets you determine this. I have not found a way to do this on the Sony. the switch is very easy and convenient as opposed to going in the menu and turning stuff on and off. So the full auto switch is kind of useless to me if it always has auto WB involved.
I had hoped for some features with the app that would help me when I have the camera up on a high stand. Mainly being able to change the white balance setting from preset to A or B. It only lets you alter the existing WB setting. This is a big deal when you start filming in sunlight and the game goes under sodium vapor lights. Also the ability to turn output characters on or off. So much potential but I am not sure if Sony is open to develop this or not.
Auto focus is solid but I came across a few situations where it sticks on a subject and it will not let go. I have two flower pots in my front yard and zoomed way in, the first pot gets locked on. Many times when I slid over to the 2nd pot it just stayed with the 1st pot. If I moved extremely to the edge it finally grabs the 2nd pot. Not the best imho. I executed the same shot with my CX-350 and it was perfect. Now, this was with "human priority" set to on in the menu. If I turn this to "off" the two pot scenario executed flawlessly. So the smart AI stuff is not smart enough yet...
Then there is the attached image. All of this white and edge stuff to grab on this house and it is STUCK on this skinny branch. I could not get it to let go of this branch.
These are specific situations and overall, the AF is acting well. But for general videography, there is room for improvement.
Will I upgrade? It is a tough decision. The Sony image does look more refined than my current cameras along with great features. As Doug mentioned, it is an evolution of the camcorder. I wanted it to be a slam dunk but life is always more complicated than that...
