Ted Ramasola
I was curious about the soft image when using 96fps so I did some resolution chart test.
I shot the usual chart to be able to compare the various framerates and see if the other framerates are soft as well.
Lens used is a canon24-105 f4L, no speedbooster to remove that equation.
iso are all at 800.
manual whitebalance.
First I shot 4K at 23.976 as a reference.
For FullHD I reframed the chart since 4K has more crop than at 1080p.
Then first HD shot at 200 Mbps to see if the high bitrate improves resolution compared to 100Mbps.
I also shot at 60P.
Then shot VFR from 2fps up to 96fps.
RESULTS,
200Mbps and 100Mbps Full HD shots resolves the same resolution at around 800+ lines. 24p and 60P yield the same result of around 800+.
Then the interesting part, shooting VFR, 2fps up to 60fps yields same result as non VFR fullHD shots, 800+ lines.
starting from 72, 84 and 96 fps is where the degradation occurs. the softness is aggravated and resolution goes down.
Here is a summary chart showing the vertical res.
Here's a summary of the center target.
Go here to see the side by side of all the VFR settings.
https://www.facebook.com/media/set/?set=a.755871411136593.1073741834.312706892119716&type=1
iso are all at 800.
I also shot at 60P.
RESULTS,
