If I have the kit lens attached with the camera powered ON, can I just take it off and attach a new lens without turning the camera off? I know that when you attach other lenses that don't work with the camera you can do that because the camera doesn't know there is a lens attached in the first place, but what about with ones that are specifically designed for the camera like the kit or the 16mm. Is it okay to just pull em off or would you recommend shutting down first?
Thanks.
Thanks.
