Thanks Hornet! The processors are already installed on the board on this PC. I was wondering how the i7's would stack and found that there were 3 ver. of the i7 processor. Serching the web I found very little benchmark testing comparisons. But the Xeon' were not bad, or far behind the i7's in testing.
Do you really feel that the i7's would boost the production over say, the HD, OS, or ram selection?
From what I've been reading, the processors "nowadays" are pretty much all good! And the biggest factors are the OS and hard drives for getting the pedal to the metal.
----------------The i7 chips are MUCH better than the older gen quad cores. The i in i7 means that the chips can read, process and write all at the same time (the older quads can only read, process then write one step at a time). This new chip design allows faster/more access to the disk, so a fast disk set up will certainly help with the overall performance and editing. I personally have the disk set up as-
1.) One 300gb 10k rpm Raptor for the OS
2.) Four 250gb 7,200k rpm RE3 drives set up as four channel RAID 0 via PCI express RAID card for editing
3.) Two 1tb 7,200k rpm Caviar Black drives for storage
If you wanted even better performance you could replace the Raptor with a 15k rpm Seagate Cheeta and the four 250gb RE3 drives upgraded to the Raptors.
I'm curious if anyone is setting up a "RAM disk" for temp files. I haven't done this myself but it seems like it's worth looking into now that most people have a ton of extra ram to spare.
-John
What are you using for an OS? And editing sw? Thanks! Ron
WoW John! That sounds like a great setup! Are you happy? Would you do anything different at this point? What do you think is the biggest bottleneck to a perfect work flow? Thanks so much for your input and advice. Ron
i will go ahead and post my whole set up. I originally had this posted in dvinfonet with full pictures, however, i had to pull the thread because i received a threatening email shortly after posting. I informed chris hurd about it and all he did was wait a week and repost it at my expense. Needless to say, i encourage everyone to think twice before posting pictures of private property in a public forum.
1.) antec 1200 computer case
2.) kingwin mach 1 1000w sli ready power supply (can support two nvidia cx cards)
3.) intel core i7 3.2 extreme (overclocked)
4.) asus p6t ws professional workstation motherboard
5.) monsoon 3 lt heatsink
6.) arctic cooling mx-2 thermal compound
7.) nvidia quadro cx with rapi hd encoding
8.) corsair 6gb ddr3 1333 overclocked to 1600 with the xmp profile in bios
9.) western digital caviar black 1tb x2, 3gb/s (dual processor, 32mb catch) 7,200rpm
10.) western digital velociraptor 300gb, 3gb/s 16mb 10,000rpm (for dual boot operating systems)
11.) western digital re3 250gb 16mb x4 set up as four channel raid 0 via pci express controller card
12.) sony bwu-300s 8x blu-ray burner
13.) rosewill multi format card reader (internal)
14.) cyberpower battery backup
15.) vista 64 and xp
