danabnormal
I'm planning my first shoot and as part of this I'm doing test shots to ensure that I'm able to get the shots that I want in the best possible quality.
The following WILL be considered newb. For that I apologise. However I hope you will see that I have tried to do my homework. So....
I'm using a 7D with a stock EFS 18-135 lens. As I understand it the capabilities of the lense will come in to play but more of that in a minute.
VIDEO MODE
I'm shooting PAL, so have select 1080p/24 for the 'film' look (as I have seen it described). I'm also set the colour profile to the custom flat setting as has been recommended on numerous sites.
ISO
As I understand it the native ISOs for the 7D are multiples of 160 and I should be looking to stick with the lowest ISO possible. I have found 160 to be impractical in the settings I'm looking to shoot (dimly lit bedroom, very early morning outdoor shots) but have been trying to not go past 640. Is this a practical limit? Should I not be scared of going past this? I know that higher ISOs offer more light but less noise and, obviously, I'm looking for the cleanest capture possible.
fSTOP
As I am shooting 24p I've been running the aperture at 60 (180 degree rule) but have found, in combination with the ISO setting, that the video is very very dark. Dropping to 30 helps immensely but what do I loose when doing this? I assume I'll be getting more motion blur as apposed to clean, vivid movement. I'm also aware that shooting at 60 gives some banding from various light sources (I'm shooting in the UK).
Am I being too stringent with the settings I'm using? I only have the one lense, and I believe that the lense type can determine the shutter speed you use but know little beyond that.
The results I've tested so far with the above give very very dark and I think I understand why, but what I'm battling with is the best way to combat this.
Again, I apologise profusely for the 'newb' post but I'm determined to get these ironed out prior to continuing with my project.
Many thanks in advance,
Daniel
VIDEO MODE
ISO
fSTOP
Daniel
