Configuraiton:
MacBook Pro, OS 10.5.6.
DuelAdapter.
I'm having a lot of trouble getting the DuelAdapter to work reliably with my laptop. In particular, in exactly this situation, it mounts correctly:
-- I boot the machine, insert the DuelAdapter with a P2 card already in it.
At that point, the P2 card mounts correctly, and I can eject it, insert another, etc., and everything is fine.
However.
If I then remove the DuelAdapter and plug it back in, or plug it in the first time without a card in it, it does not work. The particular symptom is that the ExpressCard icon appears in the menu, but clicking on the icon doesn't pull down a menu, and System Profiler does not see an ExpressCard in the slot. At that point, the only solution I have found it to reboot and proceed as above.
Any thoughts as to what might be going on? Many thanks!
DuelAdapter.
However.
