I think the question about e-mount was about being able to add readily available speedbooster adapters to the camera. I assume electronic control would be useful but not a deal-breaker since an e-mount (or perhaps mft) would still allow easy access to many adapters with focal reducers.
Certainly seems like an MFT mount would make a lot of sense for sharing adapters and lenses and focal reducers with Panasonic's gh4/5/5s cameras as b-cams.
Yes it would, but even with the EF/PL mount removed the remaining lens mount turret FFD is still longer than a E Mount, so it just will not physically work, same for a MFT mount, the FFD is shorter than the camera allows. A EF Mount FFD is 44mm, and a PL FFD is 52mm as previously pointed out. Even if the EF mount is say 10mm thick, that leaves the turret at 34mm, so a 18mm E mon t or 19.25mm MFT Mount is not going to physically work, which is why I said this was a non starter to begin with.
IF the V35 had swappable mounts, I may have bought one last year. My dealer was selling one of their demo units and approached me before they advertised it(so to speak) with a price that was too good to pass up(less than an LT), but being stuck at PL only* keeps it out of the running for me, because I'm sitting on ~$30K worth of Canon CN-E primes that are EF mount. At least the LT can swap between PL and EF, BUT it's not a great system. It takes way too long to change the mount vs. FZ and you need tools, unless you wanna fly fast and loose and not tighten the retaining screws on the mount collar(which I actually started doing when I had the demo unit).
In theory it could be done, and it would then support the two Fujinon lenses. It's just a question if there was a business model to support making any.
Emount IP is owned by Sony but it is available. From my understanding however it is really difficult to obtain the license. Only big companies and few and far between at that....The question of adapting a “dumb” E Mount, or even a active E Mount (not too likely) would require a license from Sony, as it is their Patented Mount?
As for the two Fujinon zooms, MTF Services is making a MFT Mount mod for them, so perhaps you can have the E Mount conversion done as well? Just a thought.
Cheers.
As for the two Fujinon zooms, MTF Services is making a MFT Mount mod for them, so perhaps you can have the Canon EF Mount conversion done as well? Just a thought.
Cheers.
The VariCam 35 and VariCam Pure use the same mount system as the VariCam LT. The difference is that the VariCam LT is the only one with the electrical interface and control for EF lenses. But you could absolutely use a VariCam 35 with an EF lens mount and then use manual lenses such as your Canon CN-E Primes.
Also, tightening the set screws on the VariCam mounts really is the Panasonic engineers using both belt and suspenders. It really isn't necessary and the mount stays in place just fine. If I was sending the camera up on a helicopter rig then I'd tighten the set screws, otherwise it makes no difference. Without bothering with the set screws, switching the lens mounts is super-fast, taking just a few seconds to swap.
Id wondered that in the past and had thought I could probably bag those set screws, the sleeve tightens down enough.
In theory: maybe.
In reality: no way.
Instead of the EF or PL mount adapter, the VariCam LT's neutral mount is quite shallow. It may be close enough to allow an adapter to Sony's E mount. Just barely.
BUT...
An EF - to - LT Neutral Mount Speed Booster should be pretty straightforward - assuming there's not too much mechanical and optical "stuff" in front of the sensor - , and would add a path to high quality low cost f/2 zooms and f/1 primes for your camera. Huge numbers of Speed Boosters are sold to Sony FS7/FS5 users for this exact purpose. You've already got the electronics worked out between the LT and the EF mount. So . . . . .???
Brian is it possible to make .53x SB cover apsc just by increasing the diameter of the BMPCC (SB) elements?
