LuckyStudio 13
The Tapeless One
Balancing Act.
Balancing Act.
Without 35mm adapter. A D size RedRock Gear Ring should fit your EX Focus Ring.
With 35mm Adapter.
The Rig is just a LITTLE tad Rear Heavy. I assume with another 8 gig card in the slot and with the bigger capacity battery to compensate for a mattebox, the setup should balance perfect.
A riser kit is needed if you want to fit a mattebox to your setup. RedRock Micro Mattebox looks very nice but wont be available till Jan - Feb.
Depending on the setup of the mattebox, You might want to go with a double rail system. Here is a good cheap alternative to the Zacuto Z riser at 1/3 the price.
Stay tuned, more reviews of the EX to come including footage (I have to find a server to host the footage though).
Balancing Act.
With 35mm Adapter.
