Sony PXW-Z280 & PXW-Z190 4K cams
A 5.6mm lens on 1/2" is the same FoV as 18mm on s35 which is ~64 degrees.
Which is exactly what I said, so this camera does meet Sam's criteria.
In fact, the 17x zoom range on the Z280 beats the pants off the Sony 18-105 or 18-110 or 28-135 lenses that are often used on the FS5. Oh, did I mention the Z280's lens is f/1.9 (vs. f/4 on those other lenses) and comes free with the camera?
I agree. That was the main feature that I, and many people visiting the Sony booth, felt was missing from the camera. I was lobbying very hard with the engineers to fix this oversight and I think they recognize that it is much more important than they had anticipated. I went through this same scenario last year when the Z450 didn't have S-LOG3 because they didn't think that Z450 customers cared about S-LOG. But after pushing hard for it, the Z450 got S-LOG later in the summer. I'll be really surprised if the Z280 and maybe even the Z190 don't get 120 fps HD. Maybe even before they actually start shipping, but if not by then, hopefully in a firmware udpate soon after. Even emails I've gotten from the engineers after NAB shows it is on their minds.
Thanks for the info.
According to Abel Cine's original FoV Calculator(their new one does not appear to have "ENG" formats like 1/2" and 2/3"):
A 5.6mm lens on 1/2" is the same FoV as 18mm on s35 which is ~64 degrees. And going on to "FF", a ~29mm(28.7) lens on FF is the same FoV as 18mm on s35.
Agreed
It's fairly easy to work out the comparative values of lenses vis-a-vis sensor size.
A Super 35 film frame diagonal is 28.5mm. Divide this by the 1/2" chip diagonal of 8mm. The resultant crop factor is just on 3.56. Multiply this crop of 3.56 by the 5.6mm wide end of the Z280 lens and the result is a 19.95mm wide lens in S35 terms.
In the case of the Sony S35 sensor in the FS7 that has a diagonal of 27.1. Doing the same exercise as above 27.1 / 8 = 3.38 x 5.6 = 18.97mm within a few fractions of a mm.
As an exercise take a FF diagonal of 43.3 / 8 = 5.41 x 5.6 = 30.29 wide on full frame. Again within a few fractions of a mm.
That's the way I have always worked for lens comparisons and it's not failed me yet.
Chris Young
Greetings from sunny Zambia
It's good to talk on degrees not ff, s35 or whatever - does anyone know the degrees of a 4.7 2/3 lens? I think it's about 75.
I like 75 degrees - 65 probably won't get u fired but will never be fun.
Doug - Give a 65 degree to a network eng guy and he won't be happy - that seems simple.
Oddly I'm here with some lenses - not mine - boosted 15-30 24-70 nifty50 and 70-200 - I want to ditch one to save weight - humming on "can I get by with 75 degrees?"
Doug
1.8 vs 4 - that stat is not so clear - I think the transmission of ff35t4 is about the same as 1.8-2/3 when accounting for the smaller chip
Again the 4.7 2/3 lens or 24ff seem about the same - and good.
Doug
First you say that you'd be interested in the Z280 if it had a lens that was as wide as an 18mm on a super35. I show you that that is exactly what it has, but then you say that isn't good enough. And now you are trying to tell me that the lens isn't really f/1.9 because of the sensor size? That's ridiculous. Fortunately I have better things to do with my time today that listen to this kind of nonsense and chase someone around in circles who apparently just wants to debate for the fun of it.
The cameras are not aimed at you. IMO.
There's a lot of people fumbling around with big sensor cameras who really need to take a look at 4K cameras like these. They don't need shallow DoF -- but they do need decent zoom lenses with fast apertures and lots of other great features (such as 10-bit 4:2:2 4K) that cannot even be found on NXCAM-based cameras like the FS5. These are the right tools for the right people . . . but not for everyone.
1/2? The z150 was 1'. How does this stack up in low light performace? I need a solid ENG/Corp event cam.
The Z190 and Z280 are aimed squarely at the ENG/Corp event cam markets.
In my casual observations, both of the new cameras have much better low-light capability and lower overall noise than the 1" Z150 and Z90 cameras. Don't let the smaller sensors fool you into thinking a bigger sensor would be better for low light. Maybe if all other things were equal, but they are not. For one thing, the signal processing is much better on the new cameras and they have faster lenses. I look forward do doing a comparison between my Z90 and the Z280 when mine (hopefully) arrives in July.
I'll make my last comment on the lens - basically a 4.7 2/3 zoom is still basically King of the hill - anything else is a downgrade - I'd love that capability to come to a camera that had a smaller form - full eng cams are just too much for me to schlep about.
That capability would seem possible to deliver by Sony with digitally controlled element positioning digital correction and digital zoom at the long end.
Hi Doug,
Do the cameras have the original Cinegammas or equivalents to match up with the EX series cams? Also is the Venice-like profile in these cameras or is there an intention to provide it in a future firmware update? I know the FS5 mkII has this profile included. For those of us who do multi-camera live-edit shoots with Sony cameras having Cinegamma equivalents would obviously be a boon.
Thanks for all of your info and knowledge that you are dispensing here (and what you have done in the past).
Hi Doug,
Thanks, Andrew.
The cameras offer Hypergammas not Cinegammas. HG4 is the one I recommend and was the one I used on both cameras at NAB, along with a few other custom settings. The default look is not nearly as good.
Don't get me started on the FS5M2. As I understand it, whatever it has in common with the Venice is just when you turn it on in the factory-default mode. Basically, the camera just offers a better default look out of the box for customers who are too ignorant about the paint menus to bother doing anything else. If someone just wants to turn the camera on and start blasting away, maybe they'll get a better look? But I wonder if that level of customer would really see the difference anyway? As soon as you choose a PP memory bank and start building a custom profile from scratch, as I highly recommend that anyone do, whatever the camera had in common with the Venice is gone and a FS5M2 will basically look identical to an original FS5 that has the same settings. The new Z190/Z280 cameras don't get involved in that stuff. You need to turn them on and paint them so they look great, just like every other XDCAM that came before them.
Thanks Doug. Two small follow-up questions on colour management on these cameras. Are the paint controls on the cameras in question similar to the controls on the XDCAMs of the past? Finally, are the 3 different SLOG gamma modes along with Cine EI available in these cameras as well?
I wouldn't go out on a limb and say the menus are identical because I didn't have time to look through them all, but yeah, they are pretty much all the normal paint menus you'd expect to find on an XDCAM.
The Z190 has several variations of HLG, but not does not have S-LOG. Which is good because it's only an 8-bit camera in 4K anyway. On the other hand, the Z280 has the same HLG options as the Z190 plus S-LOG3. It does not have S-LOG2 and it does not have a CINE EI mode. S-LOG3 is handled a little differently on the non-cinema cameras such as the Z280 and Z450. That's all I can say at this point because I haven't had a chance to use the camera in S-LOG mode yet. But I have no reason to think it won't look very good, but the workflow will be different in post than for a camera that has a true CINE EI mode -- and I you won't have any MLUTs onboard the camera.
