Sony PXW-Z280 & PXW-Z190 4K cams
I was thinking about the 'joy' in these cameras. While sorting out some kit.
Wireless headphones. Is this so hard?
Where are sony bringing any fun to these cameras?
So dull.
Pretty darn close... but agree with Sam on the lens - I wish it were a bit wider. Price announced today??
Also, curious Doug, any reason they went with SxS instead of XQD dual slots?
You can get a 0.8x WA adapters that will hold focus throughout the zoom range and give you roughly a 24mm FF WA FOV. They are not cheap ($500+), but very handy to have.
PXW-190 price is $4,000 and the PXW-Z280 is $7,000.
So, I keep reading that this camera will also use SD cards, but I don't see dual sdcard slots. Will it take sd cards with the use of an adapter like the EX1r? The xdcam cards are on the expensive side when you head up into the 128gb and higher range.
Yes, I saw the single sd card slot, but figured it was for firmware upgrades and camera setting backups. Sony has no info in the specs on that slot that I saw.
Which camera are you asking about?
The Z190 has dual SD card slots for recording video files, plus a third SD slot at the rear for a utility card that can be used for storing scene files, all files, user menu files, etc. -- plus record video proxy files.
The Z280 has dual SxS card slots for recording video files, plus an SD slot at the rear for a utility card that can be used for storing scene files, all files, user menu files, etc. -- plus record video proxy files. The Z280 can also use XQD cards in an adapter with any of the camera's recording formats (including 4K @ 60 fps) as long as the XQD card is rated for that bit rate. The same thing can be said about the SxS cards -- the card must be rated for the selected format. So old and slow SxS cards are not going to be allow 40K @ 60 fps. The Z280 can also use SD cards in an adapter, but not for any 4K formats. HD only.
Sony seem a bit lost on the sxs vs xqd?
I get that some prod cos might want to milk life from thier sxs stock but is there further reason for this?
I have an answer, but first I need to correct something I said earlier in post #29. BTW, I have already edited that post to correct it. I said that XQD cards in an adapter could only be used for 4K upto 30 fps. Good news -- that was wrong. The Z280 can use XQD cards in an adapter with any of the camera's recording formats (including 4K @ 60 fps) as long as the XQD card is rated for that bit rate. The same thing can be said about the SxS cards -- the card must be rated for the selected format. So old and slow SxS cards are not going to allow 40K @ 60 fps.
The reason for making SxS cards the native type of card is because they allow maximum compatibilty for customers who are upgrading from an earlier XDCAM camera (such as the X200) that uses SxS cards. And also for customers who will be using the Z280 as a B camera to a Z450, F55, etc. that also uses SxS cards. Obviously the Z280 is going to make great little grab-and-go camera for owners of the bigger cameras who still want to record 10-bit 4:2:2 XAVC-I and S-LOG on the run.
However,if someone would prefer using less expensive XQD cards they can easily do that with an inexpesnive adapter. But if XQD cards had been chosen as the native format, a lof of customers would be pissed they couldn't use their SxS cards. Makes perfect sense to me.
Thanks for clearing that up Doug. As a current PMW-300 owner (and I had the EX3 before that) I'm quite interested in the Z280 as an eventual possible "4K successor" to it. Lots of SxS cards in my kit bags! Nice move by Sony...but I really want one with the viewfinder arrangement of the PMW-300! I'm less concerned now about the interchangeable lens option as I've never taken the lens off my PMW-300 since I also bought a FS5 in 2015 for the entry level 4K and wide range of lens options that brought to the table.
I would love to know why they didn't add HFR recording to the camera. Seems like a missing piece that would be easily added and round the camera out.
Nope, you're not getting that. But I find the design of the grip to be more comfortable than the EX1.
Don't lie to me Jensen! I WANT MY ROTATABLE GRIP!! It CANT be comfortable when wanting to hold the camera close to your chest and using the LCD screen, I've never looked through the evf of a camcorder and Im not about to start. I even took it off.
Tell me how Im going to do this with dislocating my wrist?..
And I have never used a camera handheld without looking through the LCD viewfinder. If you don't want to hold the camera proerly, then finding a comfortable postion is going to be tough. Good luck with that. :-)
Haha, burn!
Sony does make a rotating handgrip, it's called the CBK-PXWFS5...I think it costs $5000. :-D
I think Fujinon took the V-grip off of their B4 lenses a while back didn't they?
Paul
I spent a great deal of time with a Sony engineer discussing the PWX-Z280 at NAB and for my purposes this is an absolute beast of a camera. 4K 60p, 4:2:2 10-bit internal, 3x 1/2" CMOS sensors, HDR (via HLG), Face Detection autofocus, 12G-SDI, genlock, timecode, 17x optical zoom, LANC control. Maximum aperture is a constant f/1.9 throughout the entire zoom range - so nice. When shooting (recording) in 4K, SDI output can be ANY format you want, including 1080p or 1080i (for broadcast purposes). 1080p is a perfect downsample from the entire frame. Additionally, when shooting in 1080p, there is the option of a 2x extender that does a center crop and allows you to double the zoom range - that means on the long end, you're over 1000mm (full frame equivalent) with no digital magnifying of the image. LCD, SDI, and HDMI are all available at the same time in 1080p (have to give one of them up when in 4K). Best of all, though, this camera has the LEAST SDI lag of any modern camera I've seen - it was plugged in directly to an SDI monitor and camera movement was instant.
Low light performance looked absolutely excellent - we dialed it up to 12db of gain and I couldn't see any noise in the picture (and I'm pretty picky about that kind of thing).
I shoot concerts, theatrical stuff, corporate presentations and the like, and wide angle is almost never an issue. Getting reach absolutely can be, though, so I like that this lens favors the long end. I almost only ever shoot live these days, so HFR is useless for what I do (if I was to shoot something narrative/commercial I'd want a camera with a bigger sensor anyway). The only thing that gives me pause is that this is the exact same lens that Sony used on the PXW-X200, which was previously emblazoned with "Fujinon HD Lens" on the barrel. They've scratched off the "HD" on the new model, but I wonder how good the resolving power actually is for a UHD camera.
That aside, I'm incredibly impressed with this model and it absolutely sets the bar for all integrated-lens cameras in the sub-$7K space.
