Sony FS100 Firmware Fix Wishlist
Did they remove Zebra's and other information currently not output via HDMI?
That was one of the baggiest features for me on this release...Any knowledge Rick?
Actually I never use Zebra ... prefer just to set 80% "Zebra point" in histogram, and it is in output.. I can see it on monitors -->
and I always trying to keep my histogram do NOT go over it...
What is important to see on external monitors is all that NEW Aspect Ratios, but not in just regular Mode, but when "display" is OFF !! The GUIDES HAVE TO BE there, even NOTHING else is not !!
When I talk about it with Sony guy, I was trying to explain him my simple opinion, based on expirience: as an Artist, I'd like to see LESS info on display, when I start shooting, so I prefer turn display OFF, but my ASPECT RATIO GUIDES, a specially, when I shoot in 2.35:1 format MUST TO BE AVAILABLE ANYTIME .. don't you think so??
I failed to double check what I had posted and hastily mentioned just Zebra's
and "Other" information. My most important item would be Peaking.
I just shot a documentary where I purchased and used a Zacuto Top Handle
and naturally it blocks the screen from going past about 90 degrees.
I was shooting most of the footage on a skateboard with my Zacuto
EVF as my monitor. It has it's own version of peaking which is just
over sharpening but it really wasn't a good option for the task.
The function to send out peaking over HDMI is what I really wanted
for this task.
Sorry I didn't clarify the other 'Other' part.
Also to get over this issue I ordered and used the Rokinon 8mm
for the project. For the money...it's a great lens. Everything is
in focus...always haha. So with the lens and just tilting my EVF
down and using it as a small lightweight monitor the shoot was perfect.
for this task.
Don't know what others think about it, but on my FS-100 I found that Peaking is NOT AS GOOD AS IT HAVE TO BE - on my new Lilliput -7 external monitor I see objects STILL NOT IN FOCUS, even on FS-100 LCD peaking tell as it is there .. a specaly on wide shots... so, I use this monitor to precise focusing, instead it Peaking option..
...and I'd like to see other users opinion about it... maybe it's just MY camera problem?
I've noticed a couple of things since augmenting my FS100 with a Zacuto EVF: firstly, the FS100 peaking doesn't pick up in 'low-lights' (EVF does). Second, if I may be somewhat bitchy, the Peaking 'Lo/Med/Hi' settings could be, IMHO, better labelled 'Sharp/Soft/Blurry' as to what to highlight. Okay, I'm hamming it up on the last point, but I was never a fan of these forms of Focus Aid.
Anyone else prefer the old-fashioned analogue style peaking? Looks like an overcooked 'Detail' enhancement. When I first tried the Z-EVF, it was with a 5Dmk2 which drops down the res whilst recording and really emphasises the 'ringing' effect. Of course, the FS100 doesn't do that, and so the peaking is quite subtle. Dialling it up does the same as the FS100 peaking control - showing fuzzier areas as 'sharp'.
I guess we're all looking forward to the ability to punch in closer, and to move that area around the screen 'a la DSLR' with the new firmware - which will be a boon to all users of f1.2 lenses for interviews.
I was using the peaking at 27db with the on-board LCD, didn't have anything out of focus, was shooting at f4.
That´s the main reason I got the TVLogic monitor over the DP6 - the peaking is superb and even finetuneable, according to your color, light or glass situation.
Frank
Having a touch screen and the Sony NEX autofocus lenses, you should be able to touch the point you want the camera to focus on while shooting.
... You give me a new idea :) -->
What about algorithm wich make possible to PROGRAMM some kind of "Racking Focus" ??
For example: with open "RACKING-FOCUS" SETUP we touch FISRT point you want the camera to focus .. than touch SECOND point you want the camera to focus .. and set the SPEED for changing focus from first to second point ...
Seems crazy.. I know.. :shocked: but I can imagine how to use it when shooting narratives - on rehearsal we can set it to match actors movement, and then, when we start to shoot - have it SMOTH and PRECISE ... :)
Steve Jobs would pounce on that. That's why Apple set record sales last quarter. Too many companies seem to just stare into the headlights.
The Epic does that.
I'm excited about the Firmware patch and not at the same time.
Brings along a couple decisions.
Anyone looking to pair some A Mount lenses with an LA-EA2?
Played with the 16-50 the other day when I was in NYC and
it's very much a DSLR lens...feels very plasticky and the
focus ring wasn't super desirable.
That paired with it being restricted to F/3.5 because
of the adapter makes me sad. Wonder is it worth
the hassle and drawbacks?
Still it wouldn't be hard to convince me to get a A77
for some stills action and have the lenses work double
duty for the FS100.
Anyone got some thoughts on this matter?
I would be looking at these lenses:
Sony 16-50mm F/2.8
Tamron 70-200mm F/2.8 (Should have never sold my Canon 70-200 F/2.8...)
I have the 1650 and la ea2.
I believe the part about being restricted to 3.5 is ONLY if you're using AF. (turn off af and get 2.8 to 22)
Edit I also have the 28-75 sal 2.8
Trust me friends, I am so ready for the firmware update. I just got the camera, the LA-EA2, a collection of lenses.Started off the build with fine Berkey components and to finish off the quartet a project around the corner. It would be nice to have it all playing together. Brubeck comes to mind......
What about 24-70mm f/2.8 Carl Zeiss Vario-Sonnar T* , Telephoto 85mm f/1.4 Carl Zeiss Planar T* , 135mm f/1.8 Carl Zeiss Sonnar T*, 16-35mm f/2.8 ZA SSM Carl Zeiss Vario-Sonnar T*, Distagon T* 24mm f/2 SSM ??? they are also "feels very plasticky" ?
..and , if I understand right - with adapter we can use ANY aperture UP TO F3.5 ( like F1.2, F1.4, F1.8, F2, F2,8 ) in autofocusing mode.. in case to give enough light to autofocusing sensor in adapter... right or no ?
I don't know the answers... never use Sony lenses yet... I hope someone are able to tell me about it :)
To my knowledge you can only use aperture settings above F/3.5 (Or the lowest setting on the lens down to F/3.5 naturally)
Worth noting that the translucent mirror also cuts down on a minor bit of light. Not a full stop by any means but enough to
mention briefly.
Videohog do you have any potential confirmation on this information regarding the ability
to open up wider if you aren't using AF? This could potentially sway me. After hands
on with the 16-50mm I felt like I was using a Canon lens and not really in a good way.
I really dislike not having hard stops. And the focus ring just felt well limpish? Hard to
really explain. It might be one of those things that well it's a small annoyance
but worth the headache/troubles. In terms of what it offers (I was using it on an
A77) it seemed great. Crisp, contrasty all of the good stuff.
B&H had a FS100 rigged with some A mount SLR lens I used a bit and It had quite
a small focus ring. The image was great I just remember disliking how small the ring was
for focus. It was nub like wish I could remember what lens it was oh well.
Can you speak to any of these items Videohog?
Is it not a big deal, thoughts etc.?
I assume using a follow focus will be just like using a canon lens. I used
them more often in 'On the go' shooting, so no marking disks usually. Wonder
if it's totally annoying to hit focus marks repeatedly..?
Hopefully it's not a bad decision to lock myself into a lens that
only works for one manufacturer...been there was it is annoying
when it's time to switch.
