Haha... ok ok.
Back on track FS100, take it away!
just remember gents, dynamic range is a look too. and changing your iso, changes that. whether you see it straight out of camera or not, once it hits the color suite, what you shot is what you get. these cameras aren't shooting RAW![]()
and generally speaking, to do that is to set your ISO for the look you want, dynamic range wise, and use the rest to mold image. everything is is situational.
regarding item :2) When I close the LCD panel on the camera, the histogram should continue to work on an external display, but it doesn't. This is a bug.
....................my histogram appears on the DP6 when the lcd panel on the camera is turned off, facing down.
NEVER MIND: I knew I couldn't believe my eyes, the histogram is there, but it isn't changing.
Have the option that the STATUS CHECK screen shows only the camera LCD, not on an external LCD, for one thing that would allow viewing the STATUS CHECK audio meters full time if desired, or any other function while you continue to record viewing the external LCD.
A balance control over sound channels1 and 2, so when you are recording one mic to both channels, you can record one channel lower than the other to give you options in editing if you didn't have the inputs adjusted just right for varying conditions. The EX1 has this.
