i actually prefer the look of the middle test the most.
GH2 is just greener.
are you using the same lens on both cameras?
There is my test: http://vimeo.com/25624225
If you known how to reduce red tint on skin color, public your picture test before and after correction please.
This means very little without any information regarding picture profiles and film modes and white balance and lighting.
So they were not white balanced or framed the same? There's your first problem. And you used Standard gamma/matrix and standard film mode? Cameras will always look different, but you can make them look very close if you use custom picture styles properly. Seems like this is not really an issue, it is not surprising that two very different cameras' awb and stock picture settings would give you a pretty different image result. If you don't like one, adjust it to your liking.
you can't compare different lenses and their color rendition
some lenses render skintones differently
it makes no sense when you compare two different cameras with different lenses
