Hi there, sure I understand the huge improvement the FX6 has over my FS5 codec wise but it's usability in the field because the XDCAM menus and options are so much more flexible and designed for professional interaction, making the camera an easier to use tool (if that makes sense). Doug Jensen sums up the differences between the XDCAM and the ones like my FS5 brilliantly in several sections of his introductory Z280 video...which is also very high (in fact at the top!) of my list to replace my PMW-300 as well.
In particular see at around 6.30; 7.30 and 11.30 in on the video and you'll get the gist of how I also think about this.
https://vimeo.com/297946781
So what I'm asking is, does the FX6 now have menu options like the XDCAMs (last clip delete, ability to custom name clips...no more Clip0001, 0002 etc., Clip duration display etc. etc.) or would it be more like the FS5 still. Thanks!
If that the default music that plays when filming with the FX6? Is there a way to change it?
So I understand that the Sony FX6 doesn't have a super 35 mode... only full frame.
But I heard the clear image zoom of 1.5x (or is it 2x?) can basically give you an exact 35mm sensor image size?
Is this true?
Does sony clear image zoom give this camera an EXACT 35mm sensor field of view when being used?
Tnanks, one more noob question.
I own regular (non full-frame glass). If I use my regular old glass on the fx6 in 4k mode with the 1.5x crop enabled... will this be the equivalent of a super 35mm camera or do I need to use actual full-frame glass to pull this off?
In other words are my old glass (non full-frame) going to work?
Could I use Clear Image Zoom in UHD/4K to work with super 35mm lenses?
Short answer is yes, in some modes. The longer answer is maybe. For a start clear image zoom is not available when shooting above 60fps or when outputting raw. As you need to typically use between 1.4x and 1.5x zoom there is a small but noticeable loss of image quality. It’s slight, but the images are a bit softer and look a touch more processed. Any noise becomes more noticeable as the noise grain gets bigger. It’s not horrid, but the image definitely loses a little of the crispness and clarity that it normally has. This isn’t really a surprise as by the time you have zoomed in by 1.4x you are upscaling around 3.2K to 4K. You could use it if you really need to, but it’s a shame to use it as it just takes the edge off what are otherwise exceptionally good images, it’s definitely not comparable to the FX9’s proper 4K s35 mode. I will put together some example images soon.
Might also be disablbled in RAW. IDK, but best to confirm.
I couldn't resist.Bahahahahaha! You're reading my mind!
I couldn't resist.
How to shoot cat videos with the FX6!
