Grug
F55 is a great camera but it is old. It is heavy. It requires a big heavy tripod that costs used more than people spend on a new A7 SIII.
Same with the Varicams, great cameras but the P2 media, ouch. And same story, you need a big, heavy expensive tripod to do a
camera in this class justice. For both cameras, you generally need a really nice, heavy expensive PL mount or EF mount lens to do the camera justice.
i think you are finally seeing that except for certain situations, the older tech has been surpassed by the newer, smaller, lighter weight tech. When I rent
either of those cameras, it's a whole thing, big tripod, batteries, expensive media, expensive lenses. A new camera like a C300 MKIII can do most everything an
F55 or Varicam can. Maybe not quite at the same level, but with a LOT less weight, and money for support, lenses, media.
If people are shooting a feature or episodic today, they're going to usually want an Arri, RED or Venice, not an F555 or a Varicam. If they are doing stuff a few notches
down from those, they probably want a smaller, lighter, newer camera. Not saying they aren't great cameras at an amazingly low cost. But buying one is a commitment in
a way that may or may not work out for people's overall business strategy.
While I agree with most of what you're saying, I'm not sure we can really levy the "heavy" tag on the F55/F5. The bodies are only 2.2kg - the FX9 is 2kg, and the C300iii/C500ii are 1.7kg. So there's really not much in it. Add a v-mount to the newer cameras and they're all sitting in basically the same place.
So the older Sonys certainly don't force you into a higher bracket of tripod if you're using them with comparable lenses/accessories to the newer cameras (which the FZ mount certainly allows you to do).
If you're shooting raw, well there the new Canons definitely pull ahead a bit weight-wise (thanks to recording it internally), whereas you have to add an extra 654g with the R5 recorder on the F55/F5 (and a whole lot more with the expansion module and external recording monitor on the FX9). But either way, rigged comparably, all of these cameras are pretty close to one another.
The newer cameras certainly bring some great advantages with them. But none of those differences are quite so night-and-day that the previous generation have been suddenly rendered obsolete. So I think it pays for people to weigh up the advantages very careful before parting with their hard-earned these days.
