joema
How are the ProRes RAW datarates compared to BRAW? Unless you're a Final Cut user, looks like BRAW makes more sense in terms of cost and support at the moment...
BRAW has adjustable compression and data rates, which is an advantage. It is very fast and smooth on playback because it's partially debayered in camera. This also allows them to bypass RED's patent on in-camera compressed RAW since BRAW is technically by the barest definition not real RAW, but in practical terms it has all the advantages and characteristics of RAW. In rough terms ProRes RAW data rate and file size is about equal to ProRes 422 HQ, and is smooth to edit on both FCPX and Premiere. I haven't tried it on AVID or Edius but ProRes RAW is (or will be) supported on those NLEs.
Currently BRAW is supported on BMD cameras plus the C300II and EVA-1 if you get the BMD Video Assist 12G. Even though anyone can use BMD's SDK to *decode* BRAW, I think *encoding* BRAW is still proprietary to BMD and they haven't licensed this to anyone else. By contrast anyone can license and decode OR *encode* ProRes RAW.
ProRes RAW is not tied to any camera manufacturer and is currently supported on about 12-15 cameras via Atomos, and Atomos claims it will be supported on 30 cameras by end of this year. Currently (or imminently)-supported cameras: Nikon Z6/7, Sony FS5, FS5II, FS7, FS7II, FX9, Canon C300II, C500, C700, Panasonic EVA-1, S1H, Varicam 35, Varicam LT, Z CAM E2, DJI X7.
The Kinefinity MAVO Edge will support internal ProRes RAW, not using Atomos. I don't know how they deal with the RED patent. The DJI X7 seems to side-step the issue since technically it is not internal to the camera but integrated into the Inspire2 airframe SSD package.
For the A7SIII the big question is what 16-bit RAW format will it support. Sony showed a 5" Atomos recorder connected via HDMI. I'd tend to think that might be ProRes RAW since Atomos already has the licensing and tech worked out for the S1H and Nikon Z-series, but we don't know. I just hope it's not a proprietary Sony RAW format which requires conversion with Sony software.
