Again you could jump up to the z system for larger lenses, though I've used the p system filters on fx1/z1s and canon xl series and not seen any vignetting. Obviously it probably depends on the lens you're using.also some folks who have tried the cokin p filters and who have put more than one filter on the cokin adapter have found vignetting issues.
Isn't that also infrared contamination that happens with all CMOS chips when adding lot of ND in bright sunlight? I think Sony EX-1 has it worst.I heard if you stack them they turn pink or something.
If anyone has used HiTech let me know. At $80 a filter, Lee is pricey
Hey J Davis. I'm in a similar situation, looking into the Cokin P filter system and looking for the best bang/buck ND filters. Stumbled onto this discussion on different neutral density filters for the Cokin P system. A couple people use and recommend the HiTech brand. One calls them a cheaper alternative to Lee, but better quality than Cokin.
If I go the Cokin P filter system route, I'll definitely be using HiTech NDs. However, I'm still debating whether the Cokin system is the way to go or if I should just use screw-in filters with step-up rings as recommended by Kholi. Using lens hoods seems a lot cheaper/easier/better than the options available with the Cokin system.
I did the step up ring approach with my last cam. Was considering the P holder route because I want it for use with Scarlet later on but I've changed my mind.
Its because I bought a bunch of used FD lenses and I love shooting with them. A cokin P holder will just really dwarf them and part of the beauty of the GH1 is its discreet form factor. In the end I elected for step up rings and 62mm tiffen ND filters which are around $15 each. Very affordable. That way the cam is still fairly low key and won't attract too much atttention. (provided the I'm not doing sound)
PAHW!!
That' my very same reasoning. I think Matteboxes and all that will have a place, the range and freedom will probably come from traditional step up ring adaptations etc.
Don't forget to shop Ebay for your needs, you can get them i nbulk for about 3 dollars each. Also, make sure you grab some cheap 62mm caps in bulk off'a ebay as well.
I think I got like 10 77mm front caps (pinch lock) for 15 dollars shipped?
Circular Polarizer I got was also Hoya, it's done quite well so far. Think I'm going to pick up a Linear Polarizer to go with my Circular Polarizer for a Variable ND.
From Kholi's suggestion I actually stepped up all my lenses to 82mm. This way I only need one set of filters for all of my lenses. Saves me money in the long run, although I'm having trouble finding a good 82mm lens hood that can accept a filter so I can still use the pola and circular pola. So, yes, you can step up to whatever size you want and it shouldn't hurt your image. However, don't forget to get a hood to reduce light hitting the glass that will affect your contrast and/or add flares.
