... on the inside (under the iris rods) where it is out of the way but easily accessible.
If you go female rosette on the grip and have me install a rosette on the EXT arm you benefit by eliminating any lateral offset caused by introducing a Crony or worse, the SmallRig part that is much larger. I never thought of this and wish I had! It seems the perfect way. I will bore a 1/4" hole thru the end of the EXT arm and fit a stud with a thumbwheel on the inside (under the iris rods) where it is out of the way but easily accessible. It's $120 rosette installed on grip. $65 for rosette installed on EXT arm and $45 for making a stud/thumbwheel and modifying the arm with a thrubore. $225.
