Eric Coughlin
I'm trying to figure out the jib situation for my C300 Mark II. I've got the Kessler Jib Pocket Traveler right now, which works pretty well with the C100 Mark II which is about 6-7 lbs with my setup, and with the 701 head I use on the jib, that puts it at 8-9 lbs. The jib is rated for up to 10 lbs. With the C100 Mark II, it's a little shaky, but I've managed to get good shots with it and it's so small and sets up so easily that I actually use it (unlike the larger Hollywood Microdolly Jib which I have but never use).
My C300 Mark II setup is 10-11 lbs, which with the 701 head would be 12-13 lbs, which is above the listed capacity of the jib. So what's a good small jib for the C300 Mark II that sets up quickly?
I have a light 5 lb carbon fiber Gitzo tripod legs (rated for 55lbs ) which I like to use which fit into my Hollywood Microdolly track. At 12 lbs for the camera and head, figure on 15-20 lbs of counterweight, then that would leave the max weight of the jib itself at around 20 lbs before going over capacity on the tripod. The Pocket Jib Traveler is only 5.5 lbs.
I've heard people on here recommend the Long Valley Seven Jib before. I don't see any specs on their site for the weight of the jib or if it has a pan lock. What are some other good options for quick one-man-band setups?
Or maybe I should just use the C100 Mark II on the Pocket Jib Traveler. Or use a field monitor (which means more setup time, and I typically handle the Pocket Jib from the front, not the back where a field monitor would be mounted) so then I can take the LCD off of the C300 Mark II which should make the weight more manageable on the Pocket Jib. Or, get a Canon 1DX Mark II with all the better auto-focus features, internal 4:2:2, and 4K, and use that for jib shots with the Pocket Jib Traveler.
