Most definitely not. This ain't P2, this is SDHC, and pulling a card out during recording could very well ruin the card. And, besides, the AVCCAM cameras don't allow it to happen at all. The door over the recording slots is interlinked with a switch; if you open the door it'll immediately terminate recording (to keep you from popping a card out while it's being accessed).Anyway, is there any way to test a card failure on one card, and make sure it keeps rolling on the other? can you pop out a card while recording?
It's absolutely 100% solid; if you have any issues it's with your software. If you want seamless clip spanning you have to import the footage into an AVCCAM-aware system that knows about the clip metadata and uses it. If you do that, it's frame-accurate and seamless.Also, while we're at it? has anyone tested the "relay rec" to see how clips are stitched together, whether there's any glitching, etc?
Yes, some 40+ prior clips. And yes, new clips get added into that existing structure.Barry, when you say the card in slot two "had a bunch of stuff on it", do you mean previous AVCHD video, or just random files? If the former, were the new clips written into the existing AVCHD structure? Interesting...
Two cards is the limit. If you want a very long PH recording, well, you can get six hours on one 64GB SDXC card; two 64's would give you 12 continuous hours of recording. And that's as long as AVCHD can do anyway, in any circumstances. Even if you had two 64's and you put the cam in HE (6mbps) mode, it would still terminate the recording after twelve hours.Ah… so relay record only works for two cards… you can't swap out the full ones for, say, very long PH recordings…?
As I understand it it's for simultaneous creation of a backup copy.Is the simul rec then likely to be backup or fault-tolerance?
I don't know the answer to that. Interesting question... I'd have to get a known-bad SD card to try that with. My guess is that it would stop the recording, because it knows that you want two copies and if it can't provide two copies it'd let you know.That is, will recording continue if there's a problem on one card, or will the camera throw up an error and stop recording on both?
Yes it does stop when the shortest-capacity card is full.And, will both recordings stop when one card is full? That may make sense of the OPs question - interpret the message to mean "using the lowest common denominator capacity, which right now is the capacity of card 2". This makes sense too even as information if the OSD only shows one remaining capacity number…. Mystery solved , one way or the other?
This could sound valid and pretty logical Jan, but it doesn't match with what happened to Barry in his test.I think the message is meant to flag the operator that simul recording is on and to put the lower capacity card in slot one. That way the camera will know when to stop recording.
so i just like to know if any one else with the 160 is having these issue
