While this is true of many third party lenses, none of the focus rings on the Nikon F-mount Sigma lenses I've used have rotated in the Nikon direction. From what I can tell, all Sigma lenses rotate in the Canon/Lumix direction. JKrepner's Zeiss is probably a ZF model, which rotates in the Nikon direction. Zeiss ZE lenses are made to rotate in the Canon direction.About the focus ring turning to opposite direction, this is a Nikon feature. Most Nikon lenses have the focus and aperture rings running to the opposite direction from Zeiss and others. A 3rd party lens with Nikon mount often follows this principle. Same lens with other camera mount may have rings rotating the usual way.
I have the Sigma 20mm f1.8, and I like it very much. It is a very video-friendly lens, with an outer barrel that neither extends nor rotates, and its focus ring has hard stops, unlike the HSM focus ring on the Sigma 30mm and 50mm f1.4. I've used Sigma 20mm, 24mm, 28mm, 30mm, and 50mm primes, and they all mate very well with the GH2. Auto-focus on the 30mm and 50mm Four Thirds models is very slow, however, but works well in low light. The 24mm and 28mm are very close-focusing macro lenses, and their barrels extend slightly as a result.
The weak side of all the Sigma primes is soft corners at wide open apertures. The 30mm is the softest, as it's not designed as a full-frame lens. The 20mm is also very soft at f1.8, but is much sharper at f2.8. In terms of sharpness, I'd rank them best to worst as 50mm, 28mm, 24mm, 20mm, 30mm. The ones I decided to keep are the 50mm, 28mm, and 20mm.
