No, actually the reason is so that you can emulate the traditional 180-degree shutter of film cameras. "Realistic" and "smooth" motion have nothing to do with it. Consider this: Video cameras, in NTSC land, have traditionally shot 60i, which is 60 motion samples per second, despite the nominal frame rate being about 30 fps. Yet the default shutter speed for (NTSC) video cameras is 1/60th second. 60i shot at 1/60th has been associated with the "live" or "local news" or "reality" look. So that directly refutes your claim.The rule is usually to have your shutter speed set to twice your frame rate for the most realistic and smooth motion for video.
which shutterspeed should I use for:
1) normal shoots / PAL / 25? 1/50
2) scene with fast movements / PAL 25p? 1/100 or above
3) fight scene / PAL 50p? 1/100 for slow motion or in general for 50p
Thank you!
I think it’s very clear. 180 degree for 30p would be 1/60 and for 60p would be 1/120 (especially for smooth slow motion). Anything higher would give some sort of judder in the image (if that’s what you want). But this is where you would have to experiment to see what YOU like. The next guy would probably want a different setting and so on.But for example, I'm a skateboarder myself and I'd like to film some 30P skateboarding, and some 60P skateboarding to playback at half the speed for smooth slow footage. What should I set my shutter speed to for both situations? 180 degree shutter often isn't 'clear' enough.
