BhambuNath
Hello Friends,
I'm getting little problem with shutter speed using GH1(PAL)
There are times when I can set the shutter speed to less than 1/30 but other times it refuses to go down than that(I'm always using it in Creative Movie Mode 720P).
When I first noticed that I can't go below 1/30, I tried everything but it did not go below 1/30 until noticed in the menu that it is in 1080 mode and before I was in 720P mode and when I set it back to 720P I was able to use the shutter speed less than 1/30.
Later again when I turned it on I found that the shutter speed refuses to go below 1/30. I checked in again if I have accidentally set it at 1080P, but it is set to 720 and I can't get it below 1/30.
I think it has nothing to do with 720 or 1080 mode and maybe I'm making some mistake which is causing this problem or otherwise it maybe some kind of bug.
The firmware version is 1.1.
Thanks.
Thanks.
