I've been wanting to get a 7D for a while. Is it still worth buying one, or is there something new coming out?
One more thing, is there a significant difference in quality between the 7D and 5D?
Thanks.
Yes, same frame rates, 7D is doing 8 fps continuous shooting in stills mode though while t3i is doing 3.7 fps, but if your main purpose is video you shouldnt bother...Interesting. I'm looking into the t3i. Does it shoot the same frame rates as the 7D?
Yeah I might get a t3i. There are a couple of things better on the 7D, but not very significant when it comes to video quality. I'd like to watch a couple of documentaries and shorts shot with one though. I'm not sure if it's my imagination, but most of the videos I find on the internet shot with a t3i, don't look as good at the 7D. Again, it could be my imagination.
The T3i is fairly new...so there is bound to be fewer outstanding videos than the 7D...which has been out for quite a while. Check out Phillip Blooms footage with the T2i...just for a reference. It looks just as good as the 7D stuff he's done. The one thing you lose with the T3i that you get with a 60D and 7d that may affect IQ for certain scenes is the ability to select in between ISOs.
You mean changing ISO settings in the middle of recording a video? (Sorry I've never used DSLR's)
The T2i (without a hack) and T3i only go in full stops 100, 200, 400, 800, 1600, etc.
...consider having a 5D as a b-cam. The reason I say b-cam is because the 7D has the appropriate-sized sensor for cinema, but when you're shooting a tight location, the extra room around the edges of frame can be the difference between getting the shot and getting f**ked.
Or you could just get a wider EF-S lens for your crop-sensored camera.
The 5D offers one thing that the other DLSRs and prosumer camcorders don't - the vista vision(video) size sensor and the very shallow dof that goes with it. Also the lowlight ability of the 5D is better than the APS C Canons- 7D, 60D, T3i, T2i.
Exactly...a 10-22, 12-24, etc. will be spectacularly wide in video/film aspect ratios. No need to buy a 5D for that, unless you want ludicrous wide!
