Should I just dump FCPX for something else?
RW60
I am about out of my mind as I write this.
I can't seem to be able to import my FS100 footage into Final Cut Pro X for editing.
Oh, I can view it as a .mov file, and that's it.
Using Clip Wrap...does not work. The files are uneditable, when converted to ProRes, or AIC.
ClipWrap gives me (migraines) no, kidding...just .mov files...
I do want to shred that moustached icon though.
This iMAC rig was not cheap, but right now I feel like burying my right foot in the 27" screen.
A solution I read that I had great hope for, failed.
User said just drag the files into Quicktime, and export them to FCPX.
Great, except all of the export options are greyed out!!!
The cam when USB'd to the iMAC is not recognized, so I am importing from a SDHC Card,
and then begins the journey into madness.
I'm sitting in what is supposed to be The Creative Cave, not The Rubber Room!
Anyone out there with The (low cost, can't miss) solution?
Help!
How do you do you import the footage?
I have no problem whatsoever getting my footage from both my FS700 and EA50 to work flawlessly in FCPX. And as far as I know they use the same file system as the FS100.
What version of FCPX are you using?
Seems like you re overcomplicating things - plug the card from the camera in - press Cmd+I in FCPX, select the card from the menu, and then the clips you need will appear.
I have no issues importing FS100 footage directly into FCPX - can edit native files, or transcode on import.
Hey guys,
Import...
I am using the very latest FCPC with all of the recent updates...just bought this loaded iMAC in October...
Have tried importing the way I used to with the Canon Hv20...the pulldown menu from up top, which only offers
Import > Media. The FS100 is never recognized when USB connected...
The files (two files created last night) show up as sson as the Card is inserted, but without a wrap, they're just a pair of AVCHD clips sitting
beneath the timeline, as in read-only fashion. I can preview them...but not work with them.
There isn't even an option to transcode, it is grayed-out, like almost every other menu option (during these import attempts).
When I have brought FS 100 files in using Clip Wrap, converted to ProRes 422 (HQ) or AIC, FCPX says it can't open the files in QT format (!)
Something isn't right. It is so frustrating because even though I am new to the Mac world, I made a decent video/DVD inside of my first
month, when working with the Canon HV20. Life was simple...! Files just fell in and could be grabbed and placed on the timeline. Too easy...
There's a reason I am thinking alternate software - (Adobe?) because it's easier to do that than give up a camera I really like.
Nothing personal: so I'm just going to ask it; are you using a genuine version of FCPX? Last time I heard a guy had greyed out parts of FCPX he was using a pirated copy.
OH, did you download the ProApps codecs after you installed FCPX? There's a download of some things that appear in the App Store Updates section after you install FCPX.
Thanks for the input guys...
Simon,
My FCPX was an App Store purchase...I think it's ok...(should be!!!)
Nate,
I had seen that vid a couple of days ago, but I think I see something in it
that might leave me red-faced w/ embarrassment...
At work til 7, so I can't do anything until then, but wanted to check in...
Thanks, again, everyone.
Ron
Nate,
Imac...SD card...FCX...Event...Import media...CMD A the AVCHD files. Done.
Not sure whats making you mental other than a corrupt file or copy of X etc ...
This must be done; otherwise you don't have access to the ProApps Codecs. It is a separate step from downloading the app.
Run software update, or go to the FCP X Menu and choose download additional content.
Something is just not right.
Tried again, following the video Nate posted about.
I inserted the SDHC Card.
The Card "No Name" appeared in the upper left, without a command to Import, and simultaneously, the two AVCHD files (clips) also
appeared at the bottom half of the screen.
I highlighted the two AVCHD files and hit the Import All button at the bottom.
I got the prompt menu, gave the newly-created destination folder a name, under McIntosh HD Projects, and hit Import.
Nothing happened. No editable clips appeared. The newly-created file was found in the "middle" of my old HV20 files.
Good Lord, when I clicked on it, the preview was of footage from last fall (!)....HV20 stuff (!)
Downloading Premiere Pro CC and will give that a go.
Will contact Apple and complain - loudly - and will suggest a trashing of my FCPX and a re-install.
I'd just move all of that fall footage to an external drive, and wipe the current FCPX off my dock.
I know darn well the software SHOULD function as it does in the video Nate linked to, but honestly, watching
that video seems other-worldly...like I'm light years from things going that smoothly.
COULD BE I am without the Pro Apps and that is the issue. Cannot think of a more rational explanation that that right now
but my patience is severely worn, as I have been at this for three days (after work).
Thanks for the posts, gentlemen, I appreciate your taking the time.
-Ron
You have to download the pro apps separately as mentioned above. Have you tried downloading them as detailed by David Saraceno's post above?
By the way, the Adobe Premiere boards are full of people complaining about problems with the software ( the same as with all software programs)! You need to go through the issue systematically; starting with finding out whether you have the codecs installed or not...
Open your hard drive and go to the Library folder. In it is the QuickTime folder.
All the ProApps QT codecs should be there including Pro Res, DVCProHD, AVCINTRA, etc.
If they're not there, you must download the additional content.
Sounds like you are doing something wrong to be honest. Can't understand what you are talking about really.
If you put the SD card in the iMac, the hit cmd-I in FCPX, choose NO NAME (or whatever name your SD card happen to have).
You should then see a list or previews of the files. You should be able to skim through the clips. And select on or more then hit "import selected clips". After that a dialog box will appear asking you what library and event you want to import the to.
You out should not be transferring the files from the SD card to your Mac before this. Import directly into FCPX from the card.
--- Poor articulation on my part, perhaps.
If you put the SD card in the iMac...you should then see a list of previews ...
--- two seconds after placing the card in the Lexar card reader, the card name appears in FCPX
and the two AVCHD clips on it appear also...
--- Sure, but I bet I have tried to achieve that 50 times or more, in multiple ways.
That rudimentary development is what used to happen with HV20 clips.
Has yet to happen once with AVCHD
files, and if it had, even just once, this thread likely would not exist.
Apologies if I fail to re-create the misadventure in a manner that makes
sense, but this crap doesn't make sense, and it is tough to write when
I am both stumped and totally pi$$ed.
Gosh. SUPER WEIRD. Sorry you're having all these issues, the whole reason I like using FCPX is the simplicity.
I'd say trash the app and re-install. Deleting the app itself won't delete your libraries/events so no need to transfer them to an external drive. You don't happen to have Perian or something like that installed?
Apologies if I fail to re-create the misadventure in a manner that makes sense, but this crap doesn't make sense, and it is tough to write when I am both stumped and totally pi$$ed.
Can you confirm for those of us attempting to assist whether:
1. You have the pro apps codecs installed in your quicktime folder; and/or
2. You have downloaded the "additional content" as required for installing FCP X?
Several have asked, and you haven't responded.
David,
Was just speaking to a MAC user here at work (our graphics person) and explained I don't "see" a "Library" FOLDER, where I should.
And then a quick search revealed it can go "missing" and CAN BE "re-loaded" so I will have to do that this evening.
I am 55 per cent certain you have identified the FCPX issue, and whether on my own or with help from Apple, I SHOULD be able
to get this resolved.
I am off for four days starting tomorrow, and have this evening to dig in to it, so I am hopeful I can turn the ship around sooner
rather than later.
Thanks for your continued interest and support; Nate as well.
-Ron
PS: My colleague says ONE thing to look into is deleting Preferences in FCPX. Ensure it is shut down, and delete.
She says that will allow for a re-loading of default settings and might help with the current issue...
