So I have a Audio Technica 4073a but need phantom power for that bugger so I am looking for a cheaper bolt on shotgun that connect right into the GH3 now that I can monitor audio!
How about this -Audio Technica At897 - looks to have similar specs but a little longer than my 4073a ? I'll hopefully be booming with the more expensive mic but for backup sound around $200 ????? (I have actually rigged up the 4073a via a battery powered presonus firebox into the GH3 and it works like a charm with a small amount of noise! - diy field mixer!!! - yes I want a sd302 but $$$$$)
4073a - $900
[TABLE="width: 548"]
[TR]
[TD]ELEMENT[/TD]
[TD]Externally polarized (DC bias) capacitor[/TD]
[/TR]
[TR]
[TD]POLAR PATTERN[/TD]
[TD]Line + gradient[/TD]
[/TR]
[TR]
[TD]FREQUENCY RESPONSE[/TD]
[TD]20-20,000 Hz[/TD]
[/TR]
[TR]
[TD]LOW FREQUENCY ROLL-OFF[/TD]
[TD]80 Hz, 12 dB/octave[/TD]
[/TR]
[TR]
[TD]OPEN CIRCUIT SENSITIVITY[/TD]
[TD]-29 dB (35.5 mV) re 1V at 1 Pa[/TD]
[/TR]
[TR]
[TD]IMPEDANCE[/TD]
[TD]50 ohms[/TD]
[/TR]
[TR]
[TD]MAXIMUM INPUT SOUND LEVEL[/TD]
[TD]141 dB SPL, 1 kHz at 1% T.H.D.;
151 dB SPL, with 10 dB pad (nominal)[/TD]
[/TR]
[TR]
[TD]NOISE[/TD]
[TD]13 dB SPL[/TD]
[/TR]
[TR]
[TD]DYNAMIC RANGE (TYPICAL)[/TD]
[TD]128 dB, 1 kHz at Max SPL[/TD]
[/TR]
[TR]
[TD]SIGNAL-TO-NOISE RATIO[/TD]
[TD]81 dB, 1 kHz at 1 Pa[/TD]
[/TR]
[TR]
[TD]PHANTOM POWER REQUIREMENTS[/TD]
[TD]48V DC, 4.8 mA typical[/TD]
[/TR]
[TR]
[TD]SWITCHES[/TD]
[TD]Flat, roll-off; 10 dB pad (nominal)[/TD]
[/TR]
[TR]
[TD]WEIGHT[/TD]
[TD]99 g (3.5 oz)[/TD]
[/TR]
[TR]
[TD]DIMENSIONS[/TD]
[TD]233.0 mm (9.17") long,
21.0 mm (0.83") maximum body diameter[/TD]
[/TR]
[TR]
[TD]OUTPUT CONNECTOR[/TD]
[TD]Integral 3-pin XLRM-type[/TD]
[/TR]
[TR]
[TD]ACCESSORIES FURNISHED[/TD]
[TD]AT8405a stand clamp for 5/8"-27 threaded stands; 5/8"-27 to 3/8"-16 threaded adapter; AT8144 windscreen; two O-Rings; protective carrying case[/TD]
[/TR]
[TR]
[TD]AUDIO-TECHNICA CASE STYLE[/TD]
[TD]SG2[/TD]
[/TR]
[/TABLE]
At897 $200
[TABLE="class: productlist lists, width: 100%"]
[TR]
[TD="class: specs"]ELEMENT[/TD]
[TD]Fixed-charge back plate, permanently polarized condenser[/TD]
[/TR]
[TR]
[TD="class: specs, bgcolor: #ECECEC"]POLAR PATTERN[/TD]
[TD="bgcolor: #ECECEC"]Line + gradient[/TD]
[/TR]
[TR]
[TD="class: specs"]FREQUENCY RESPONSE[/TD]
[/TR]
[TR]
[TD="class: specs, bgcolor: #ECECEC"]LOW FREQUENCY ROLL-OFF[/TD]
[TD="bgcolor: #ECECEC"]80 Hz, 12 dB/octave[/TD]
[/TR]
[TR]
[TD="class: specs"]OPEN CIRCUIT SENSITIVITY[/TD]
[TD]Phantom: -40 dB (10.0 mV) re 1V at 1 Pa
Battery: -41 dB (8.9 mV) re 1V at 1 Pa[/TD]
[/TR]
[TR]
[TD="class: specs, bgcolor: #ECECEC"]IMPEDANCE[/TD]
[TD="bgcolor: #ECECEC"]Phantom: 200 ohms
Battery: 300 ohms[/TD]
[/TR]
[TR]
[TD="class: specs"]MAXIMUM INPUT SOUND LEVEL[/TD]
[TD]Phantom: 129 dB SPL, 1 kHz at 1% T.H.D.
Battery: 115 dB SPL, 1 kHz at 1% T.H.D.[/TD]
[/TR]
[TR]
[TD="class: specs, bgcolor: #ECECEC"]DYNAMIC RANGE (typical)[/TD]
[TD="bgcolor: #ECECEC"]Phantom: 112 dB, 1 kHz at Max SPL
Battery: 98 dB, 1 kHz at Max SPL[/TD]
[/TR]
[TR]
[TD="class: specs"]SIGNAL-TO-NOISE RATIO[/TD]
[TD]77 dB, 1 kHz at 1 Pa[/TD]
[/TR]
[TR]
[TD="class: specs, bgcolor: #ECECEC"]PHANTOM POWER REQUIREMENTS[/TD]
[TD="bgcolor: #ECECEC"]11-52V DC, 2 mA typical[/TD]
[/TR]
[TR]
[TD="class: specs"]BATTERY TYPE[/TD]
[TD]1.5V AA/UM3[/TD]
[/TR]
[TR]
[TD="class: specs, bgcolor: #ECECEC"]BATTERY CURRENT / LIFE[/TD]
[TD="bgcolor: #ECECEC"]0.4 mA / 1200 hours typical (alkaline)[/TD]
[/TR]
[TR]
[TD="class: specs"]SWITCH[/TD]
[TD]Flat, roll-off (recessed)[/TD]
[/TR]
[TR]
[TD="class: specs, bgcolor: #ECECEC"]WEIGHT[/TD]
[TD="bgcolor: #ECECEC"]5.1 oz (145 g)[/TD]
[/TR]
[TR]
[TD="class: specs"]DIMENSIONS[/TD]
[TD]10.98" (279.0 mm) long,
0.83" (21.0 mm) diameter[/TD]
[/TR]
[TR]
[TD="class: specs, bgcolor: #ECECEC"]OUTPUT CONNECTOR[/TD]
[TD="bgcolor: #ECECEC"]Integral 3-pin XLRM-type[/TD]
[/TR]
[TR]
[TD="class: specs"]ACCESSORIES FURNISHED[/TD]
[TD]AT8405a stand clamp for 5/8"-27 threaded stands; AT8134 windscreen; battery; 5/8"-27 to 3/8"-16 threaded adapter; protective carrying case[/TD]
[/TR]
[TR]
[TD="class: specs, bgcolor: #ECECEC"]AUDIO-TECHNICA CASE STYLE[/TD]
[TD="bgcolor: #ECECEC"]SG2[/TD]
[/TR]
[/TABLE]
4073a - $900
[TR]
[TD]ELEMENT[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD]IMPEDANCE[/TD]
[TD]50 ohms[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD]NOISE[/TD]
[TD]13 dB SPL[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD]SWITCHES[/TD]
[/TR]
[TR]
[TD]WEIGHT[/TD]
[/TR]
[TR]
[TD]DIMENSIONS[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD]SG2[/TD]
[/TR]
[/TABLE]
At897 $200
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
