The biggest factors are in good and even lighting.
I'd say go with 24pa so that you don't have any frames that cause you problems.
Use the marker setting to test the expouser... point it at the green screen, it should be at 40 to 50 %... and your subject should be exposed/lit up with light at about 80-90 %....
I believe the editor plans to edit at 30fps, so wouldn't 24p be better?
Also, what do you mean by "frames that cause you problems"?
Thanks for the advice!
I have to clarify, simply to stave off confusion which will inevitably show up in other NLE threads elsewhere.![]()
There is only one NLE which makes a pain out of removing pulldown from 24p standard (not 24pA) footage, and that's FCP.
Avid will remove either pulldown during capture, and all the other (pro-level) NLEs capture the footage as 29.97 and then automatically remove either pulldown on a 24p timeline, but leave the pulldown intact on a 29.97 timeline. With those, you can edit 24p standard on a 24p timeilne just as easily as you can edit 24pA. There will be no difference between the two.
