Lenilenapi
Carbonite Member
- Mislabelled as MKE 102 - actually:
- Sennheiser lavalier MKE 2 w Lectro TA-5 connector & K3 power supply with 2 position low cut roll off. (MKE 2-3)- $150 shipped
This is a top quality mic indistinguishable from a Sonotrim and to my ears better than a Tram.
(Don't confuse with much cheaper ME-2 that comes with the G2 and G3)
The TA-5 connectors allow you to use the mic with a wireless or other power supply.
Likewise the K3 power supply is the older style that takes a small 6V PX23 battery instead of the newer version K6 that uses AA.- Can be run off camera's phantom power ( using K3 without battery) or independently using battery power in the K3.
Functionally and audio quality is very similar to the modern MKE 2-60/K6 at B&H that sells for $599
Comes with tie clip and a few other access. No windscreen but that can be purchased easily from B&H- BTW these can be converted to use with a sennheiser G3 just by purchasing an adapter cable to go from TA-5 to the G3 mini connector. That's how I run my G3's and you can have a few made up at Location Sounds for less than $50.
Lenny
