SDHC dumping...
dantewaters
Is there a way to dump these SDHC cards without the use of a laptop while in the field?
If so what are the solutions?
yes, there is. but i forget what its called. but someone will remember! and post it for all the world to see!
its got usb ports and card ports(CF, SD, and MMC i think?). you put in a hard drive and its got a battery. does magical stuff.
i think its around $120?? can't beleive i forgot what its called tho...
Yea I hope someone remembers...
there's one thats advertised as being able to offload p2 and sxs(via usb), along with sdhc, cf, and mmc. it doesn't come with a hard drive tho. someone posted about here on dvxuser, it may have been in either the hvx or ex1 section. i've been trying to find it but i can't.
does anybody have any experience with the Nexto ND-2700? sounds like a good deal. im thinking of getting an hmc150 but i want to be able to dump files RELIABLY without a laptop.
I've got an older 2525 which doesn't have the SD slot but does have a CF slot. It does a bit-by-bit file comparison after copying, so you can be pretty sure that it's made a reliable copy.
HYPERDRIVE - AVCHD backup in the field.
Here is the ULTIMATE solution, and is available for many years now. I won two of these, never had any problem. No laptop. Just back up to two devices and you have the reliability you need.
http://www.hyperdrive.com
Regards,
Paul Vicente
Good Luck.
Why not just buy a ton of SDHC cards? they are cheap. I have 4 16gig and 3 8gigs. In total they have cost me less than that device. Check SlickDeals for the best SDHC card prices.
Agreed.
I got mine for P2 card offloading, but for SD it almost doesn't make sense to go to an intermediary hard drive, now that cards are so cheap...
