Cees Mutsaers
Is there a zoom remote for the motor zoom when the cam is on the tripod ? Does the HPX300 have connections for this option?
Yes it does and it is underneath on the lens, you can use the Fuji one if you can afford it but I found that the cheaper manfrotto one will not work:http://www.creativevideo.co.uk/publ...or-remote-zoom-control-on-Professional-Lenses
Best comprimise is the libec handle and there is one on e-bay now:http://cgi.ebay.co.uk/Libec-PH-9-Zo...?pt=UK_Consumer_Professional_RL#ht_500wt_1154
They normally go for around £120 2nd hand and there is also a smaller clip on one that is around that price new:http://www.creativevideo.co.uk/public/view_item_cat.php?catalogue_number=libec_ZC-9PRO
The new libec handle is also here:http://www.creativevideo.co.uk/public/view_item_cat.php?catalogue_number=libec_ph-9_remote
I have both of these and they will fit most tripods they also have rec/ret buttons and the larger handle has a dual speed control.
The Varizoom is the one we use. You do have to remove your iris rods to install the 8-pin cable, but they will fit back on once the cable is screwed into place.
http://www.varizoom.com/products/controls/vzpgf.html
e
Just clicked this and it opens in Chrome. It's the VZ PG-F. VariZoom also sells 8 to 12 and 12 to 8 pin conversion cables that allow the Canon or Fujinon controller to work across almost all lenses for start/stop and variable speed zoom.
I actually have the VZ Pro-C version, which is designed for Canon. Use it on the HVX300 / Fujinon combination all the time with the $99 Canon 8 to Fujinon 8-pin adapter cable.
