I think it's only about 2 years ago that the definition of requirements for a set to be officially labelled "HDReady" (as according to the EBU spec) was defined. At that point plasmas and LCDs were in a minority, and most didn't have vertical resolutions more than 480, let alone HDMI.DavidBeier said:Majority of what? HD sets? Maybe. I don't know the UK market well but even the majority of HD sets in the UK would still probably mean something like 3% of the whole UK market.
But go in to any large retailer now and the change couldn't be more dramatic. It's hard to find a CRT nowadays, and the few that are on sale seem relegated to a small corner. And all of the flat screens now do seem to be "HDReady". If you browse any of the consumer mags, then 1920x1080 screens are now seen as the "next big thing", and as I said, these same magazines are prophesying that in another year they will be in the majority. There is a strong chance that in two years virtually ALL screens will be 1920x1080.
I don't really want to start guessing precise figures, but by year end it's pretty certain that 3% won't even be in the right ballpark. More like 10 or more times that.
It should be the same in the US, and talk of a battle between 1080i and 720p completely ignores 1080p - certainly at 24 or 30fps, if not 60. You can't look at these forums and not be aware of the interest in 24p and film look. And whilst 1080p/60 is currently effectively beyond current technology, 1080p/24 most certainly isn't. If you want a pure, progressive signal, and if 24Hz motion is OK (as for most drama) you don't have to lose any resolution. 720p is not the only way to get progressive.Once again, I'll defer to you on the UK. I work in the US however. Here, we have people battling between 1080i and 720p. I support 720p since personally I don't mind losing a bit or resolution for a pure, progressive signal (why would anyone ever want to deal with interlace again?).
And with a 1080i transmission chain, that quality makes it all the way through. Then the signal is more properly called 1080psf/24. A decent receiver should be able to resurrect the original progressive sequence without scaling or de-interlacing.
