An important point.At $189 per 128GB XQD card, I think I'll use my O7Q and already bought 1TB SSDs
hard to justify buying 6 hours worth of XQD cards when the project doesn't pay that much.
If he has an Odyssey7Q+ it can accept UHD30p directly via HDMI without either the XDCA or the Odyssey RAW Bundle. In my brief cost comparison I did state that I was only comparing the recording media and I did so in actual dollars per minute, which is the fairest way to run the numbers.When you do the financial math do you have in mind that you will either need the XDCA or the 7Q+?
.. I think I'll use my O7Q
An important point.
Using Samsung 850 EVO 1TB SSDS (technically 1000GB), memory for the Odyssey7Q+ is currently running about 30¢/G, or about $2.30/minute in Apple ProRes 422(HQ) in UHD30p.
Using a128GB XQD card at $189/card, internal memory for the FS7 is running about $1.48/G, or about $4.74/minute in XAVC-I in UHD30p (Based on Sony's listed rate of 3.2GB/min).
Using an Odyssey7Q+, the cost per minute for recording media is less than half that of internal recording on the FS7.
I still have here a Sony statement that says that UHD 50p/60p cannot recorded with 10bit 422 using the HDMI interface of the FS7. I told that also Mitch, and he had the idea to go back to Sony with that question. Because if the Sony statement is true, then the quality should be very different if one uses an external recorderle th 7Q+ or even the Shogun, compared to he raw ouput of the FS7.
Wolfgang, I did see this information at another spot in reference to a different product but I am still awaiting a response from Sony. It is quite possible that you are correct but I cannot confirm it at this point.The HDMI-interface supports 4:2:0 8 Bit Signal for 4K/50P. Up to 4K 30p you have 422 10bit. So
4096x2160 60p/50p 4:2:0 8 bit
4096x2160 24p/25p/30p 4:2:2 10 bit
The Samsung SSDs use a marginally higher draw of power, but that just means they will drain your batteries a little quicker. You certainly are not relegated to AC power only.If you use the Samsung SSD's in the 7Q+ do you need to power the 7Q using an AC adapter or will it work from the Sony L batts I usually use?
